I have a problem with timing slides in Presenter 7. I set the timing in PowerPoint but when I publish my presentation, presenter ignores the timing and sets the time from publish settings (there is a field where you set time for empty slides) . I dont have any audio nor video on my slides I just want to set the timing to give viewer time to read slides (and I need diffrent values for every slide). I hope I explained my problem enough. I am using presenter 7 and PowerPoint 2007.
thanks
If you want to change default duration of all the slides without multimedia/animation , you can do so by updating default slide duration in Presentation Settings .If you want different duration for every slide , you can accordingly add silence in Audio Editor of Adobe Presenter which will increase the duration of that slide by the input you will provide.
-Thanks
Leo
-Thanks
Leo
Thanks a lot Leo. That helped me a lot
Under Presentation settings you could try changing the playback option of (Duration of slide...)
Or what most people do and is best and most reliable, let the Presenter or speaker move the slides manually when done speaking.
matt rock | Technical Response Team, Connect |
my.adobe.acrobat.com/mattrock
