0 Replies Latest reply: Aug 19, 2009 9:57 AM by luadke RSS
    jquery question:  Can I put tool tip somewhere other than after trigger?
    luadke Community Member
      Hope this is the right forum for this....
      the page is http://blackpaint.co.uk/BlackPaint09/films/index.html
      if you put your mouse over 'TIDE' you will see the tool tip.
      But the problem I am having is that it won't work I put the tooltip DIV somewhere else than straight after the trigger.
      This is the only place it works
      Code:
         <span class="class1">
      <span class="SlantedWritingFilms">
      <a onclick='return getPass(this);'rel="shadowbox;height=1000;width=2000" href=../flash/TIDEFullFilm.flv id="trigger" >Tide</a><div class="tooltip">TEST tooltip
      </div> </span>
      </span>
      </div>
      I want to get it outside of the stripholder div so that I can set a percentage width to the tooltip DIV - so its size will be affected by the size of the browser window and also I would be able to position it where I want. I've tried doing this with by setting the tooltip positioning to Absolute - but it has no affect.
      Can someone help me with this?
      thank you,
      hope I' clear
