Hello,
I have a couple different UI's being used. I was wondering if it is possible to figure out which UI is being used in the form, either by a call from the form itself using reader extensions or by passing information into the form through a custom render.
Any help is greatly appreciated. Thanks.
Solved! Go to Solution.
Total Likes
Ok, maybe you can use the Custom Configuration -> httpheader to get the info.
This is what I get after base64 decoding it:
��� sr� java.util.HashMap ��� `� � F�
loadFactorI� thresholdxp?@����� w ��� ��� t� accept-encodingt� gzip,deflatet� content-lengtht� 606t�
connectiont�
keep-alivet� referert�-http://localhost:8080/workspace/workspace.swft� hostt� localhost:8080t� accept-languaget� en-us,en;q=0.5t�
user-agentt�\Mozilla/5.0 (Windows; U; Windows NT 5.2; en-US; rv:1.9.0.11) Gecko/2009060215 Firefox/3.0.11t� accept-charsett� ISO-8859-1,utf-8;q=0.7,*;q=0.7t� cookiet�]JSESSIONID=8DA0362A5FBE7EEF86996EE922326E36; lcAuthToken=14AAF071-55F2-9279-A28D-39AF4F33FC55t� content-typet� application/x-amft� acceptt�?text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8t�
keep-alivet� 300x
I know it's not pretty but that might work.
Jasmin
Total Likes
What do you mean by UI?
Different forms? Different Workspace? Different web pages?
Jasmin
Total Likes
Workspace UI's.
Thanks.
Total Likes
If you have different UIs, I'm assuming they have different urls.
If the form is rendered from an input xfaForm or DocumentForm variable using a Render service, you can get that url from the Custom Configuration->TargetUrl value that is passed to the render service.
Jasmin
Total Likes
Both of the UIs are on the same server. When I pull the TargetURL value, I get the same result (http://<server>/workspace-server/submit). Please let me know any other ideas you have.
Thanks.
Total Likes
connectiont�
keep-alivet� 300x
Jasmin
Total Likes
How do you do a base64 decode of the httpheader? As long as I can get information on which UI is being loaded I don't mind having to do a little digging to get it
Total Likes
Right now I just used a web site to decode the string.
You could create a custom component or the script service and use some java code to do it through code.
We don't have a decode built in LiveCycle.
Jasmin
Total Likes
I checked by using an online web site and this does show the custom workspace URL. I'm going to create a script that will base 64 decode and then pull the UI name. Thank you for your help Jasmin!
Total Likes
