1. Re: Setting custom colors
jod-zeee Aug 20, 2009 11:40 AM (in response to jod-zeee)Bump.
Am I the only one unable to set custom colors in Captivate? I was able to at one time, but no more
2. Re: Setting custom colors
Captiv8r Aug 20, 2009 11:46 AM (in response to jod-zeee)Hi there
I'm not sure I've ever seen anyone post the same question. So it's possible you are the first to ask.
If Captivate doesn't seem to be retaining them for you, I can think of a different way to achieve it. Just create a small image containing a swatch of each custom color you want. Add that image to your library. Then when you need a specific color, you may select it from the library image.
You would also have the option to add the image to each library you work with.
Cheers... Rick
Helpful and Handy Links
Captivate Wish Form/Bug Reporting Form
3. Re: Setting custom colors
jod-zeee Aug 20, 2009 12:19 PM (in response to Captiv8r)Thanks, that's an interesting workaround. Just to make sure I understand ... I create an image with the colors I need, then when I need to change a color of something (e.g., text, line), I choose the image in the library to make it show up in the preview, then go to change the color and use the eyedropper tool to grab it from the preview.
The only problem I can see is that I'd have to make sure I remember to choose the image first before clicking on the item I want to change. Less work than typing the values over and over again!
Jo
