When I go to Publish my Powerpoint (2007, Windows XP Prof. 32-bit) slide show into Presenter (latest), and run the Presenter edition, I'm finding my text formatting is changed. Font size, alignment, spacing, etc. isn't being carried through.
Any ideas?
Need help at helper's earliest convenience, thanks.
JT
Make sure you are running Presenter 7.0.2.
matt rock | Technical Response Team, Connect | marock@adobe.com
adobe systems
my.adobe.acrobat.com/mattrock
adobe systems
Updated to 7.0.2, re-published, and still having the same problems.
Hi JT,
Am facing the same issue. My guess is that Presenter is not compatible with Vista. Cos when i publish the same presentation in XP, i do not get the text issues.
From what I understand, in the next couple of weeks, Adobe is releasing an update to P7 (7.05 I think) that should address some of these issues.
I know, I know...it doesn't help right now, but hopefully this will resolve future issues.
Here's the link:
http://www.connectusers.com/news/index.php?cmd=display_news&id=2692
Rob
www.robrode.com/yabb/
This should be fixed tomorrow in the 7.0.5 patch. Can you try it tomorrow and confirm for me?
matt rock | Technical Response Team, Connect | adobe systems
yeah, I'd be happy to.
Hi Matt.
No, 7.0.5 did NOT solve the text problems...
What font are you using? Does it happen with all fonts, or just the default font? Are you publishing to your own server, or an Adobe hosted server?
We use the Georgia font throughout. The thing is that some screens, the
title is fine. Other screens, it is enlarged and double-spaced.
Just publishing to My Computer for now.
I will be out of the office starting 20/08/2009 and will not return until
21/08/2009.
If you require urgent assistance then please contact Emma Dawson on 15832
alternatively I will respond to your query on my return.
Are you able to narrow it down to a specific size? Does changing the font give the same results?
21/08/2009.
21/08/2009.
