1. Re: caption to keywords, minus grammar
Paul Riggott Aug 19, 2009 2:33 AM (in response to riskypotato)Here is a start for you.
You will need to create a dictionary of words, I just created a text file with one word per line IE:
most
much
my
myself
neither
no one
nobody
none
nothing
one
one anotherNB: You will need to amend the code with the correct path to your dictionary!!!
The script will show up in the right click menu
#target bridge
if( BridgeTalk.appName == "bridge" ) {
CreateKeys = new MenuElement("command", "Keys from Description", "at the end of Thumbnail");
CreateKeys.onSelect = function () {
keysFromDesc();
}function keysFromDesc(){
// AMEND PATH TO SUIT!
var pronouns =File("~/desktop/pronouns.txt");
if(!pronouns.exists){
alert("Dictionary does not exit " + pronouns);
return;
pronounsList=[];
pronouns.open("r");
while(!pronouns.eof){
var line = pronouns.readln();
if(line.length>2){
line=line.replace(/^[ \t]+|[ \t]+$/g,'');
pronounsList.push(line+" ");
pronouns.close();
pronounsList=pronounsList.toString().replace(/,/g,'|');
var items = app.document.selections;
var items2 = new Array;
for (var a =0; a<items.length;a++){
if(items[a].type == "file") items2.push(items[a]);
items = items2;for (var i = 0; i < items.length; ++i) {
var item = items[i];
var md = item.synchronousMetadata;
var str = md.read("http://purl.org/dc/elements/1.1/","dc:description");
md.namespace = "http://ns.adobe.com/photoshop/1.0/";
md.Keywords = formatDesc(str);
}function formatDesc(str){
str=" "+str+" ";
str=str.replace (/[\!\"\£\$\%\^\&\*\(\)\:\;\,\'\\\/]/g,'');
var rex = new RegExp (pronounsList,'gi');
var keys= str.replace (rex, '').split(' ');
return ReturnUniqueSortedList(keys).join(';');
}function ReturnUniqueSortedList(ArrayName){
var unduped = new Object;
for (var i = 0; i < ArrayName.length; i++) {
unduped[ArrayName[i]] = ArrayName[i];
var uniques = new Array;
for (var k in unduped) {
uniques.push(unduped[k]);
return uniques.sort();
2. Re: caption to keywords, minus grammar
riskypotato Aug 19, 2009 5:56 AM (in response to Paul Riggott)Paul,
Wow this is fantastic! Okay, let's say I have this list of words: as, on, in, the, and, or, but (the real list will be much longer), and they are in a folder called "wordsnot" on the root level of my Macintosh HD. Would this be correct?
var pronouns =File("Macintosh HD/wordsnot.txt");
Also, what about punctuation marks in the caption, such as commas and periods?
Many thanks!
Phil
3. Re: caption to keywords, minus grammar
Paul Riggott Aug 19, 2009 10:51 AM (in response to riskypotato)Ah I don't think I have have checked for period and cr lf,will do that. Not too sure on the mac filepath as I try to keep well away from my Macs unless I have to. The list at the moment need to be one per line but could be changed if required.
Paul.
4. Re: caption to keywords, minus grammar
riskypotato Aug 19, 2009 11:19 AM (in response to Paul Riggott)Paul,
Well, I have composed a "starter" list of words, and inserted it into your code. But, 1, do I now need to make it into a .jsx file, and 2, where do I place this file? As I mentioned, I know nothing about this. Anyway, here's the .txt file, as it stands now:
the
a
it
and
but
on
over
under
near
around
as
they
he
she
it
aka
in
or
are
is
has
have
been
becoming
his
her
hers
our
ours
of
our
you
your
yours
their
theirs
myself
yourself
them
after
although
because
since
than
unless
until
when
while
both
either
neither
not
are
also
plus
before
then
now
can
only
to
does
do
doing
how
5. Re: caption to keywords, minus grammar
Paul Riggott Aug 19, 2009 12:51 PM (in response to riskypotato)As you say you need to make the jsx file, to do this use "ExtendScript Toolkit" this comes with Photoshop and you should find it on your Mac
<hard drive>/Applications/Utilities/Adobe Utilities
Copy and paste the code into a new window, you can then Start Bridge -
Edit - Preferences -Startup Scripts
At the bottom click the "Reveal Button" this will open the folder where the script should be placed.Close and restart Bridge so that it will pick up the script and it should be at the bottom of the right click menu.
I still haven't checked the mac path yet, but cr/lf and periods are now been checked along with other punctuation.
NB: The script only works on selected documents.
This new version works with a file with comma delimited words, this is what I used to test it...
all,another,any,anybody,anyone,anything,both,each,each other,either,everybody,
everyone,everything,few,he,her ,hers ,herself,him,himself,his,it ,its,itself
little,many,me,mine,more,most,much,my ,myself,neither ,no one,nobody,
none,nothing,one,one another,other,others,our ,ours,ourselves,several,she,some
somebody,someone,something,that,their,theirs,them,themselves,these,these
they,this,those,one,us,we,what,whatever,which,whichever,who,whoever,whom,whomever
whose,you,your,yours,yourself,yourselves#target bridge
keysFromDesc();
}keysFromDesc();
return;
pronounsList=[];
pronouns.open("r");
line=line.split(',');
for(var a in line){
var item =line[a].toString().replace(/^[ \t]+|[ \t]+$/g,'');
if(item != ' ' || item != '') pronounsList.push(item+" ");
pronouns.close();
pronounsList = ReturnUniqueSortedList(pronounsList);
if(pronounsList[0]== ' ') pronounsList.shift();
md.Keywords = formatDesc(str).replace(/^;/,'');
str=" "+str+" ";
str=str.replace (/[\!\"\£\$\%\^\&\*\(\)\:\;\.\,\'\\\/]|\n|\r/g,'');
6. Re: caption to keywords, minus grammar
riskypotato Aug 19, 2009 4:25 PM (in response to Paul Riggott)Paul,
Once again, many thanks for this tremendous help. In the next few days I'm hoping to apply this script and will keep you informed. It's something I think a lot of photographers might want to use.
Phil
7. Re: caption to keywords, minus grammar
riskypotato Aug 21, 2009 7:45 AM (in response to Paul Riggott)Paul,
Some problems getting this to work. I copied your script, named my
text file "pronouns.txt" and placed it on mydesktop. The error message
is attached, the .jsx file is in the correct folder I believe. Not
sure if I ran ExtendScript Toolkit correctly: I set the left window
for Bridge CS4, copied this text into it, and saved as "pronouns.jsx".
Here's the script I made into the .jsx file:
#target bridge
keysFromDesc();
keysFromDesc();
return;
pronounsList=[];
pronouns.open("r");
for(var a in line){
var item =line[a].toString().replace(/^[ \t]|$/g,'');
pronouns.close();
items = items2;
var item = items+;
str=" "str" ";
\/]|\n|\r/g,'');var rex = new RegExp (pronounsList,'gi');
unduped[ArrayName] = ArrayName;
8. Re: caption to keywords, minus grammar
Paul Riggott Aug 21, 2009 11:33 AM (in response to riskypotato)What error are you getting? There isn't anything attached in your last post.
9. Re: caption to keywords, minus grammar
riskypotato Aug 21, 2009 12:24 PM (in response to Paul Riggott)hmmmm... attached it to the email but it didn't show up. Anyway:
"An error occurred while running a startup script named "pronouns". It
may not be compatible with this version of Bridge. You can check for
available updates.... etc.... The script has been disabled... etc..."
Then, below, it says:
"Error in /Users/phil/Library/Application Support/Adobe/Bridge
CS4/startup scripts/pronouns.jsx
Line 29: var items = app.document.selections; undefined is not an object"
That's the whole of it.
Thanks for any help!
Phil
10. Re: caption to keywords, minus grammar
Paul Riggott Aug 21, 2009 1:15 PM (in response to riskypotato)Ooops yes there was a mistake! Sorry! This should now work, I've tested it it in CS3 and CS4.
#target bridge
keysFromDesc();
return;
pronounsList=[];
pronouns.open("r");
for(var a in line){
if(item != ' ' || item != '') pronounsList.push(" "+item+" ");
pronouns.close();
str=" "+str+" ";
var keys= str.replace (rex, ' ').split(' ');
11. Re: caption to keywords, minus grammar
riskypotato Aug 21, 2009 1:29 PM (in response to Paul Riggott)Okay, thanks. No error message. But... how do I run it? It shows up as
a startup script in the prefs, but I can't find it in any menus.
Phil
Phil
12. Re: caption to keywords, minus grammar
Paul Riggott Aug 21, 2009 2:38 PM (in response to riskypotato)It should be the last entry in the Right Mouse Click menu. It should show as "Keys from Description"
Just select the document you want to run the script on and selected the script from the menu.
Hope that helps.
13. Re: caption to keywords, minus grammar
riskypotato Aug 21, 2009 3:15 PM (in response to Paul Riggott)Obviously am missing something fundamental. Not sure what is the Mac
equivalent of the right-hand click. I don't see it in any of the
menus. Sorry to be so slow on the uptake. /Phil
14. Re: caption to keywords, minus grammar
Paul Riggott Aug 21, 2009 3:34 PM (in response to riskypotato)You can simulate a mouse with a left and right button I think its CTRL/click on a Mac this should give you the right click menu.
15. Re: caption to keywords, minus grammar
riskypotato Aug 21, 2009 3:42 PM (in response to Paul Riggott)Paul,
Indeed it does (I think i was supposed to know that!). However, when I
do that, nothing happens, keyword-wise.
Phil
16. Re: caption to keywords, minus grammar
Paul Riggott Aug 22, 2009 2:29 AM (in response to riskypotato)Hi Phil, I wonder if you have selected and documents, as it works on selected documents only?
17. Re: caption to keywords, minus grammar
riskypotato Aug 22, 2009 6:26 AM (in response to Paul Riggott)Hi Paul,
Yeah, had one selected. Does the script work for you? Grateful for all
the time you've put into this.
Phil
18. Re: caption to keywords, minus grammar
Paul Riggott Aug 22, 2009 10:57 AM (in response to riskypotato) -
19. Re: caption to keywords, minus grammar
riskypotato Aug 22, 2009 11:48 AM (in response to Paul Riggott)Paul,
Hmmm... it's working for you, though have you tried an example where
it removes the pronouns/articles/prepositions?
Still not happening for me, and it is enabled in prefs. Perhaps I ran
ExtendScript ToolKit wrong.
Phil
20. Re: caption to keywords, minus grammar
Paul Riggott Aug 22, 2009 12:06 PM (in response to riskypotato)Yes it does remove all words that are in the dictionary. I can't understand why it isn't happening for you unless the text is in a different field?
21. Re: caption to keywords, minus grammar
riskypotato Aug 23, 2009 7:03 AM (in response to Paul Riggott)Not sure what you mean by the text being in a different field...?
