Show 2 replies
1. Re: Is it possible to modify multiple states at once?
Nadia-P Aug 23, 2009 6:45 AM (in response to luadke)See if this video tutorial helps - this is for version CS3, but would be similar in CS4:
http://www.vtc.com/products/AdobeFireworksCS3/GettingStarted/69592
2. Re: Is it possible to modify multiple states at once?
SiamJai Aug 23, 2009 8:08 AM (in response to luadke)Once you have Onion Skinning turned on (like on your screenshot), multiple-click the same objects with the Select Behind tool. That make the selection valid across multiple states. Any changes will apply to all selected objects across states.
The Select Behind tool is under the same button as your regular pointer tool. Toggle between them using the "V" key.
SiamJai
