I have an Oracle database with 100K rows that I need to populate a AdvancedDataGrid. I have setup my RemoteObject to point to an destination which invokes a java class to return the values. The Java class makes the jdbc connection and creates a List of Maps and retuns the value back.
The problem I am facing is that the code throws an "out of memory" after 2K of data. Any idea on what parameters to configure or is there a better way to do this?
rgaurava
List list =
new ArrayList();
Map testResult;
while (rs.next()) {
testResult =
new HashMap();
testResult.put(
"STRING1", rs.getString("STRING1"));
testResult.put(
"STRING2", rs.getString("STRING2"));
testResult.put(
"STRING3", rs.getString("STRING3"));
list.add(testResult);
return
list;
Total Likes
You should try to setup a Data Management architecture.
The tag <mx:DataServices> will help you to activate data-paging and handle your memory issue.
Total Likes
