I've noticed that FXG, and Spark in general, has very few [Bindable] properties, while in Degrafa, almost every property is [Bindable], some of the classes event have class [Bindable] tags. I am taking advantage of this greatly.
Are you guys planning on making more of the properties [Bindable]? Or does the compiler auto-generate custom [Bindable] events in the background (that would be very nice)?
A reasonable compromise would be to have each property dispatch a custom "myNameChange" event, only if "target.hasEventListener('myNameChange')". Otherwise this forces us into a position where, to bind to the properties, we have to extend every class and add that functionality.
For instance, I would like to know when the "layout" changed on a skinnable container, and when "clipAndEnableScrolling" changes, but they're not [Bindable] like most of the other properties in there.
To prevent a performance hit, you could just do something like Degrafa does, with custom events:
[Bindable(event="myPropertyChange")]
public function get myProperty():String
return _myProperty
public function set myProperty(value:String):void
if (_myProperty != value)
var oldValue:String = _myProperty;
_myProperty = value;
dispatchPropertyChangeEvent("myProperty", "myPropertyChange", oldValue, value);
protected function dispatchPropertyChangeEvent(property:String, eventType:String, oldValue:*, newValue:*):void {
if (hasEventListener(eventType))
dispatchEvent(new Event(eventType)) // or PropertyChangeEvent....
If Flex did this in the background for properties not marked [Bindable], that would be EXTREMELY helpful, and I don't think it would change/break anything. I feel like this is already the case...
Let me know what you think.
Lance
How are you taking advantage of the bindable properties in Degrafa?
Our general policy in Spark and MXML Graphics is that only properties that can be modified by the user, or by complex computations performed by the framework (i.e., width/height), should be bindable. Other properties that are only modified by the developer can be bottlenecked by the developer, and shouldn't incur the overhead of bindability.
E.
Hey Ely,
The main example is in creating controllers that are attached to the Skins with Degrafa objects in them (like OpenFlux does it). The Controllers use BindingUtils.bindProperty to listen for when a Fill.gradientType changes, or when the Polygon.data changes, and then it updates another thing. That's the most generic part, but there's lots of that. Like creating a shadow based on the gradient angle and the position of the object.
Another example is in restricting a button's label width/height to the (rectangle width - the corner radii sizes). And those corner radii change with the state. I don't do that in the skin, I do that in a ButtonLabelController, which I can add to any skin and reuse the code. But it requires binding.
Or tilting the panel and changing the drop shadow size when the verticalScrollPosition, or any of the scrolling related variables change.
Or changing the color as a function of the gradient fill angle in a skin to easily simulate simple lighting.
For the horizontalScrollPosition/verticalScrollPosition, you can create an animated scroll bar very easily, and more fully featured than the built in stuff in Spark, with a controller that binds to those properties on a Group or Layout.
Granted you can do all this without binding, but binding just makes it soooo much easier.
Plus there shouldn't be much overhead if we're not dispatching events if it doesn't have an event listener for it, and they aren't generically "propertyChange" events. That's what Degrafa does in some places.
By not having the option to bind to it, I am restricted to a particular coding style, and I miss out on some helpful coding practices, like composition over inheritance. Currently in Spark, I can't extract out "controller" logic from the skin (that does something like the above) into some other object, unless I know when they're updated. Some other options I currently have using the Spark Architecture:
1) Write some enterFrameHandler that updated properties based on other property changes. Would require some dictionary keeping track of old property values on a target.
2) Extend the skin class and add [Bindable] tags, or extend the Group and add them.
3) Extend the Skin or component, and do a bunch of logic in the invalidation methods, which isn't necessary, especially during animations. Plus I can't reuse that logic in another component without copy-pasting, and that's just too much work. Like if I wanted to have an editable TextInput and an editable TextInput, I'd have to extend both with the same code in each. I could solve that with a Controller no problem.
I think the controller architecture makes things so much easier to do, and classes so much easier to customize, without code duplication and inheritance. But that's another point.
Binding doesn't need to be "active" if nothing's bound to it, and we can have an option to prevent binding on those properties with a variable like degrafa has: "enableEvents" or "suppressEventProcessing". That shouldn't impact performance.
Lance
Here's some stats using Grant Skinner's PerformanceTest class:
performance.BindablePerformance (10,000 iterations)
Tests [Bindable] performance in Flex
method...............................................................ttl ms...avg ms
A_DefaultBinding 1167 0.12
A_DefaultBinding_Again 1299 0.13
B_CustomBindingEvent 1249 0.12
B_CustomBindingEvent_Again 1285 0.13
C_CustomBindingEventWithCondition 1215 0.12
C_CustomBindingEventWithCondition_Again 1199 0.12
D_NoBinding 1193 0.12
D_NoBinding_Again 1203 0.12
Sorry, that one was kind of deceiving... each property was a UIComponent and I was creating a new UIComponent each iteration, so it averaged out about the same. If I change each property to a Number and just increment it, it looks like this:
A_DefaultBinding 118 11.80
A_DefaultBinding_Again 119 11.90
B_CustomBindingEvent 87 8.70
B_CustomBindingEvent_Again 91 9.10
C_CustomBindingEventWithCondition 23 2.30
C_CustomBindingEventWithCondition_Again 20 2.00
D_NoBinding 11 1.10
D_NoBinding_Again 12 1.20
... SECOND ROUND:
A_DefaultBinding 134 13.40
A_DefaultBinding_Again 122 12.20
B_CustomBindingEvent 83 8.30
B_CustomBindingEvent_Again 78 7.80
C_CustomBindingEventWithCondition_Again 26 2.60
D_NoBinding 12 1.20
... So it looks like just adding that conditional statement to check for the event listener is kind of expensive. But it's only a 2x performance hit instead of ~7-8x for dispatching an unnecessary event (like setting alpha in the UIComponent when nothing is bound to it), and the default binding, which is 10-11x more expensive!
1x: No binding
2x: Custom binding event, not dispatched (because there's no event listener)
7-8x: Custom binding event, dispatched (by default by Flex)
10-11x: Default binding event, dispatched (by default by Flex)
This might be a factor in why animating UIComponents is sooo much slower/choppier than animating Sprites or whatnot, because alpha, x, y, and whatever else dispatch events when there's nothing bound to them.
> grep -r "\"xChanged\"" ./*
> ./framework/src/mx/containers/utilityClasses/ConstraintColumn.as: [Bindable("xChanged")]
> ./framework/src/mx/containers/utilityClasses/ConstraintColumn.as: dispatchEvent(new Event("xChanged"));
> ./framework/src/mx/core/UIComponent.as: [Bindable("xChanged")]
> ./framework/src/mx/core/UIComponent.as: dispatchEvent(new Event("xChanged"));
There is nothing in the framework listening/bound to "xChanged", or most of the other properties dispatching events.
That "set x" accessor shouldn't be dispatching an event every time its set, neither should y, width, height, alpha, explicitWidth/height...
override public function set x(value:Number):void
if (x == value)
return;
if (_layoutFeatures == null)
super.x = value;
else
_layoutFeatures.layoutX = value;
invalidateTransform();
invalidateProperties();
...should become
if (x == value)
return;
super.x = value;
else
if (hasEventListener("xChanged"))
...That should help out in animations, and just make performance better in general.
Best,
Lance
I'm going to try to integrate this into the framework. It would only be one extra step to "suspendEventProcessing" during animations if you wanted.
If only it was easier to set up the sdk development environment
The avg ms figures in your last post seem off. If the test was run for 10,000 iterations the avg ms should be 0.0118 for A_DefaultBinding etc. The relative differences in the methods stays the same. Although I'd suspect something else is contributing the overall choppiness given how little even the most expensive call adds.
