also, you might try creating a file object first, initing
that with your
full path, and then passing that object into the init method
of the output
stream
"Marc E" <cf@hifiwebdesign.com> wrote in message
news:e4dlop$3t4$1@forums.macromedia.com...
> what error do you get when trying the init("/opt....")?
> that's on the right track...just using the filename
itself is definitely
> not what you want.
> what you might do to get the full path you're looking
for is create a file
> in wwwroot and do a
<cfoutput>#getDirectoryFromPath(getCurrentTemplatePath())#</cfoutput>
> that'll tell you what coldfusion thinks it is, and from
there you should
> have what you need to pass into the file init
> "DaveF67" <webforumsuser@macromedia.com> wrote in
message
> news:e4d0n6$6vh$1@forums.macromedia.com...
>>I am trying to get this to work in
Solaris/Apache/MX7. When I run the
>>code, it
>> always saves the files in
>> <cfusionserver>/runtime/bin/
>> with owner "nobody|other"
>> i need the files to read and write from
>> <cfusionserver>/wwwroot/
>> owner "www|www"
>> any suggestions?
>> files located in <cfserver>/WEB-INF/lib/
>> -rw-r--r-- 1 www www 802216 May 16 09:42
>> poi-2.5.1-final-20040804.jar
>> -rw-r--r-- 1 www www 55209 May 16 09:42
>> poi-contrib-2.5.1-final-20040804.jar
>> <CFSCRIPT>
workBook=createObject("java","org.apache.poi.hssf.usermodel.HSSFWorkbook").init
>> newSheet=workBook.createSheet();
>> workBook.setSheetName(0, "My First Sheet");
>> row=newSheet.createRow(55);
>> cell=row.createCell(0);
>> cell.setCellValue("hello world!");
>> fileOutStream =
createObject("java","java.io.FileOutputStream").init("test6.xls");
>> output
>> workBook.write(fileOutStream);
>> fileOutStream.close();
>> </CFSCRIPT>
>> I have tried using
.init("/opt/coldfusionmx7/wwwroot/test6.xls"); but i
>> get an
>> error.
>> Thanks if you can help
>> Dave
