Hi there,
I have listed my problem along with some details below. I would really appreciate any assistance or suggestions as I have already searched the forums and not come to any solution.
Problem: I can not hear audio in my published project
Already tried:
System:
Thank-you in advance,
Michelle
Already Tried (...continued from above)
...but alas still no audio.
Hi there
Can you post your output to a web page where we can click and see if we hear audio? If so, that would mean something is funky with your PC setup. If not, it would mean something is fishy with your Captivate settings that is removing the audio.
You could try with a sample two or three slide project. You wouldn't need any real content.
Cheers... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
Hello Rick,
Thanks for the quick reply.
Ja, I thought that might be the case but since I have other .swf files (not made with captivate) playing with audio, I ruled that thought out.
Nevertheless, just in case I've put up some output as you asked: http://michellepace.com/test/
Waiting for your reply, thanks
Michelle
I've just noticed something strange, in the 'Information' it has Audio: 0.0KB in spite of audio showing in advanced settings. (see below)
...any ideas?
I was having the exact same problem and searched through the forums. It turns out there's a bad dll that needs to be replaced. I just worked through the steps and now have audio!
Here's the link to the page.
http://blogs.adobe.com/captivate/2009/03/audio_play_back_and_usb_mic_is.html
Hope this fixes your audio issue as it did mine.
Fatenah
Thanks very much Fatenah... but I got a bit impatient, uninstalled version 3 and started using the trial of version 4.
Now that I realise how much better it is, I think I'm just going to upgrade to version 4 (which currently works with no problems)
Thank-you anyhow,
Michelle
