Hi -
I am curious to know if anyone has used the RH command prompt to publish a RH project using a third party application - i.e. homegrown app?
I'm thinking of creating an application that will allow RH users register their projects for knowledge management purposes. It would act somewhat like an LMS where users could post their dev files on a network share. When ready to review with the customer, the would use the registration tool to push the project to preview. The app would call the RH command prompt using a server side technology, in my case .NET, and supply the necessary arguments and push the generated project to preview. Once it had been reviewed and ready, then the user could push to production.
Any thoughts on this - reasons why this wouldn't work, good, bad, ugly, alternatives? - all constructive comments welcome
Hi there
I see some flaws with that.
Dev files need to always be local. Placing on a network share for the purposes of using RoboHelp to compile or generate is risky business and may explode in your face. LMS to me means Learning Management System. Those are typically used for eLearning. RoboHelp does help systems. Captivate does eLearning. So you are losing me with your LMS reference.
I'm lost. What "registration tool" are you even referring to here? Or is this what you are planning on creating and that's what you are choosing to call it?
There is no "preview" of projects. Preview of individual topics, sure. But not for a project. There is only compile or generate to create the final output.
Sounds like what one might typically accomplish using RoboHelp in a typical development cycle. You edit content on the local hard drive. If a review is needed, you compile or generate the content and place the output on a server. After approval is complete the content is then copied to the production server.
Sure sounds like you are attempting to reinvent the wheel in many situations here.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 within the day - $24.95! |
Thanks for the quick replay Captiv8r!
I apologize for not being more concise. For the sake of argument, lets say I have the following assumptions:
What I'm trying to decide is whether or not to build an application that can mitigate the above problems within the above contraints and resources.
My idea is to create an EPSS (Electronic Performance Support System/Solution), not an LMS - sorry poor use of the term. Also the term "registration tool" is just a generic term to indicate the purpose - to capture meta data associated with the RoboHelp project and register it in a database.
The flow would be as follows:
Hopefully it is more clear. Do you see any value in it considering the above assumptions?
Thanks again for you comments.
