Using RH8, RSC3.1 and XP.
I renamed a project per the Help instructions. When the project reopened most of the topics were no longer in the HTML file list, though they are in the
folder itself.
I would like to know how to gracefully get this project back in one piece. I imagine importing the topics is the key, but is there a better way.
I would also like to ask what happened? Did I miss something?
Any information would be greatly appreciated.
Joe
FYI, I tried importing one topic and it says it copied the file but skip the import because it is not a valid HTML file. Though I double-clicked the file and it opened in the browser normally.
I tried one more just to see if that was a one time thing and it did the same thing. I am not feeling good about getting this project back together easily.
I hope there is something I'm missing.
Joe
OK, I found the missing topics in the BROKEN LINKS folder. I was able to restore all topics with some hyperlinks being lost, but nothing else.
Is this what is supposed to happen from a rename of the project. I don't have much hair, but I think I just lost some more. 😉
Joe
I
Hi Joe
Hmmm, come to think of it, I've been using RoboHelp since 1992 and I began shaving my head several years ago. Nah, I'm sure it's not that. It's genetics.
Actually that should not happen to you. The only issue I can think of here is that you mentioned (I believe) that the project you renamed was under Source Control? I could see that having all sorts of issues. I don't use RSC, I've always avoided it. But I might logically conclude that I would need to perform the following steps if I needed to rename a project.
You may want this thread to appear in the Source Control forum. There are some sharp folks there that monitor that forum and may just sort of ignore this one. If you want, I'll be happy to move the thread there for you.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 within the day - $24.95! |
Thanks so much for the reply. I did remove it from RSC before the rename per the Help advising you could not otherwise (the option is dimmed). But I probably did not close and open the project again before doing the rename.
A tough lesson to learn, but mostly mental damage, nothing much in the project.
Thanks again.
Joe
I've experienced the same in RH8 without any source control being involved. It was fixed in the same way as you did it and the project has been OK ever since.
