8 Replies Latest reply: Aug 30, 2009 12:33 PM by Harbs. RSS
    Trying out a new client
    !Firedog Community Member
      If you build it, I'll test it
      So now I'm testing it. No geekiness here, just a bog-standard user putting this thing through its paces.
      Noel
        • 1. Re: Trying out a new client
          Let's try something formatted as JS:
          class HelloWorldApp {
              public static void main(String[] args) {
                  System.out.println("Hello World!"); // Display the string.
          and plain nonformatted (= pre, I suppose)
          Noel
          • 2. Re: Trying out a new client
            Harbs. CommunityMVP
            In the Web interface, the first one looks okay (but no formatting). In the client, neither text shows up at all!
            Email style code tags:
            for(var i=0;i<100;i++){
              alert("One day it'll be easy to use these forums!");
            noformat code tags:
            }{/noformat}
            java code tags:
            }{/java}
            • 3. Re: Trying out a new client
              Harbs. CommunityMVP
              Hmm.
              That's no good...
              • 4. Re: Trying out a new client
                Looks like oddly-formatted bits of posts don't make it back to the client. I'm sure Jochem's working on that.
                The formatting tags (see http://forums.adobe.com/servlet/JiveServlet/download/3384-445069-2024949-10091/Text+Markup +Syntax+Help.htm ) don't need slashes in the closing ones - same tag fore and aft. "code" tags should default to formatting as JS, but I couldn't see any colour-coding of reserved words, for example.
                I forgot to try an index to see whether that makes it through the filters. That has supposedly been fixed.
                (This posted from the web since I happened to be here)
                Noel
                • 5. Re: Trying out a new client
                  Harbs. CommunityMVP
                  Let's try another one...
                  Curly:
                  days = ["Sunday","Monday","Tuesday","Wednesday","Thursday","Friday"]
                  for(var i=0;i<days.length;i++){
                    alert("Maybe on "+days++" it'll be easy to use these forums!");
                  Square:
                  curly with spaces:
                    alert("Maybe on " + days+ + " it'll be easy to use these forums!");
                  square with spaces:
                  • 6. Re: Trying out a new client
                    Harbs. CommunityMVP
                    Nope. That's pretty messed up. Indexes still are no good...
                    Harbs
                    • 7. Re: Trying out a new client
                      Jochem van Dieten CommunityMVP
                      I'm not (yet) working on the way messages are displayed / posted. I just finished the protection against negative numbers of unread messages, next is reimplementing the synchronisation of threads to get rid of the messagecounts that are too high. Which is a bit of a pain, because they occur when you have a unread message in one forum that is moved to another forum or deleted before it is read, and Jive does not have webservices that publish that data.
                      • 8. Re: Trying out a new client
                        Harbs. CommunityMVP
                        Well, we appreciate all your hard work!
                        Harbs
