1. Re: Need to change an object color to another...help
Stos53 Aug 28, 2009 2:34 PM (in response to pennipeter)Hi Penni,
I don't think InDesign has any image editing functions. If you edit your image in photoshop you can change the color, remove the background and then save it as PNG, TIFF or other format that will preserve transparency.
Good luck,
-Mike
2. Re: Need to change an object color to another...help
[Jongware] Aug 28, 2009 2:44 PM (in response to Stos53)Alternatively, if you want to be able to change the color in InDesign, save the image as a grayscale one. Then you can change its 'black' component to any other color with InDesign. Use the white arrow to select the image frame 'contents' -- ID should report it's 100% black -- and then just select another color.
If the image is now green and you convert it to gray, it will become a shade of gray -- adjust brightness & contrast (or levels) so it's as dark as possible in Photoshop. That will guarantee the color in ID is 100% of the color you select.
3. Re: Need to change an object color to another...help
P Spier Aug 28, 2009 2:48 PM (in response to pennipeter)InDesign is able to colorize NON-Transparent gryascale or bitmap mode raster files only. Since JPEG doesn't support ransparency, it would be possible to add color to a grayscale JPEG in ID, but your file is not grayscale, so there is no way to change the color other than using an image editor such as Photoshop. If you decide to do that, save the edited image as either a TIFF or native PSD to avoid any more image degradation froom further JPEG compression.
If you edit and relink you shouldn't see any changes in the effects you've applied inside ID.
4. Re: Need to change an object color to another...help
P Spier Aug 28, 2009 2:49 PM (in response to pennipeter)I'm curious what you mean by "made the background transparent" since by definition a jpeg can't have a transparent background.
5. Re: Need to change an object color to another...help
[Jongware] Aug 28, 2009 3:04 PM (in response to P Spier).. NON-Transparent gryascale or bitmap mode ..
I missed that bit. You are right, to use both the image needs to be a monochrome bitmap (with that you can set the background white to transparent and the foreground black to a color of your like). Only use this if you can produce a high resolution version (higher than 300 dpi -- at least 600 dpi, and better still 1200 dpi).
If the edges of the image are rather good defined, you could try adding a clipping path to a grayscale version -- that combo oughta work well.
6. Re: Need to change an object color to another...help
You can in fact colorize a transparent image in InDesign, and it doesn't even have to be grayscale.
7. Re: Need to change an object color to another...help
Mike Ornellas Aug 28, 2009 4:00 PM (in response to P Spier)InDesign is able to colorize NON-Transparent gryascale or bitmap mode raster files only. Since JPEG doesn't support ransparency, it would be possible to add color to a grayscale JPEG in ID, but your file is not grayscale, so there is no way to change the color other than using an image editor such as Photoshop.
I seem to be able to colorize transparent objects in In design.
Untitled-1 Folder 2.zip 3.4 MB
8. Re: Need to change an object color to another...help
P Spier Aug 28, 2009 3:54 PM (in response to Printer_Rick)Ah yes, I always forget about blending modes. Somehow I don't think that's quite what most people are thinking of when they use the term colorize, though, but that doesn't mean it isn't a valid technique.
Can you suggest a way to solve the OP's color change problem?
9. Re: Need to change an object color to another...help
Printer_Rick Aug 28, 2009 4:04 PM (in response to P Spier)I could but Mike showed me how. I think he deserves the credit.
And you are correct the term colorize is extremely vague. You can colorize a one channel image in ID or AI. In Photoshop you can use Hue Sat to colorize a 4 color image. Two different things entirely.
10. Re: Need to change an object color to another...help
P Spier Aug 28, 2009 5:56 PM (in response to Printer_Rick)I've been studying Mikes files, and they are intriguing. I wonder if he'd care to share with others what the technique is, because I'm sure I haven't uncovered all of it.
I have discovered a few things. I'm not sure the Tiff is genuinely transparent, though it has areas with no color. If you save the same image preserving transparency it no longer accepts the fill color. Also, if you place this Tiff in front of other objects you'll see a white background in those areas with no color. A truly transparent image will show the other object in those areas. ID also does not seem to consider this to be a transparent image -- removing the other images from the page and tuning off the effects turns off the page transparency icon.
Likewise, the .psd is depending on a white background layer, so in effect it is also not transparent though it has transparent layers. If you turn off the background, the color disappears and cannot be reapplied. Again, ID does not consider this image to be transparent as long as the background layer is visible in the object layer options.
The PDF seems a little different, though. It was saved from the photoshop file with the background layer turned off. This is the only one of the three images that is truly transparent acording to InDesign. As far as I can tell I can't apply a fill color to the image itself (because it actually IS transparent). The yellow tint seems to be coming from the Satin effect and is applied heaviest where the color of the image itself is white. I'm not able using that effect to color the dark areas and leave the light unaffected as in the other examples, nor can I find a blending mode that will do that, so in effect I'm only able to colorize the background. I'm not well versed in effects and blending modes, however, so I might just not be trying the right combination.
All of these images are grayscale. Rick said he could do this with an image that was NOT grayscale (or, by implication, bitmap). I tried converting Mike's sample TIFF and PSD to RGB without merging layers, and the effect immediately failed, so perhaps someone will explain what I did wrong, there, too.
So far I'm not seeing anything that will allow the OP to change the blue in his placed jpeg to green without editing the jpeg file directly, either to make it grayscale or to edit the blue color, but what Mike has done is pretty cool in its own way.
11. Re: Need to change an object color to another...help
pennipeter Aug 28, 2009 6:03 PM (in response to P Spier)I figured out how to drop out the background. Is that not transparency?
12. Re: Need to change an object color to another...help
pennipeter Aug 28, 2009 6:04 PM (in response to P Spier)Genius
13. Re: Need to change an object color to another...help
pennipeter Aug 28, 2009 6:05 PM (in response to [Jongware])Yet another Genius
14. Re: Need to change an object color to another...help
Not necessarily. What did you do to drop out the background?
15. Re: Need to change an object color to another...help
Mike Ornellas Aug 28, 2009 8:32 PM (in response to P Spier)I wonder if he'd care to share with others what the technique is, because I'm sure I haven't uncovered all of it.
Hmm.
I thought by posting the files it would answer questions. You place files and there you go.
It's been like this since CS2, but CS2 colorizes files differently. It's odd that Adobe would change the behavior of the feature like this.
16. Re: Need to change an object color to another...help
P Spier Aug 29, 2009 1:02 AM (in response to Mike Ornellas)Mike Ornellas wrote:
Well, you need to be doing something more than just placing the files to change the color, no?
I suspect any behavior change might have something to with handling of transparency, but I'm not sure what change you are talking about.
17. Re: Need to change an object color to another...help
P Spier Aug 29, 2009 1:51 AM (in response to pennipeter)I did finally come up with a method for coloring transparent RGB images. I set the image frame fill to Paper, then added a second frame above, filled with color, and set the blend mode to Hue. The result isn't particualrly predictable (and does not match the color applied to the upper frame or particularly resemble what happens when you apply color dirctly to a grayscale), since it depends on both the color of the new frame and the underlying color, but the areas that were showing white in the image, or paper in the background, remain colorless.
Interesting effect, certainly, but not a technique I would employ to try to change the color of a logo, I think.
18. Re: Need to change an object color to another...help
Printer_Rick Aug 29, 2009 5:58 AM (in response to P Spier)Peter,
This will achieve what the OP wants. Blue transparent image made green in InDesign.
OP please bear in mind JPEG can't be transparent. That part of your original post still confuses me.
Please forgive the extremely low resolution of the image. I have trouble getting files uploaded in the forums. I also stripped ICC profiles to try to get the file size down.
The red box behind just shows the transparency of the image. The blue image colored green can be placed over anything with transparency intact.
Peter, while you're at it, take the AI and copy paste into InDesign. Tell me what you think. It's what I tried to upload the other day but it didn't go through.
colorized cmyk.zip 183.0 K
19. Re: Need to change an object color to another...help
Mike Ornellas Aug 29, 2009 8:46 AM (in response to Printer_Rick)I suspect any behavior change might have something to with handling of transparency, but I'm not sure what change you are talking about.
Try it Peter. Take the same files and do the same effect in CS2. You will see a more realistic colorized or expected result in CS2 vs. a newer build.
I also suspect a bug in the current CS4 build that allows colorization of some file formats that should not happen, but does when more then one file format resides on a single page.
20. Re: Need to change an object color to another...help
P Spier Aug 29, 2009 9:32 AM (in response to Mike Ornellas)Have you filed the bug reports?
21. Re: Need to change an object color to another...help
Mike Ornellas Aug 29, 2009 10:13 AM (in response to P Spier)No I have not, but I would rather improve upon the quagmire and not have it omitted from the application. So I guess, I'm stuck as far as a decision to file or not.
I don't want the option to go away is what I'm trying to say. To be quite honest, a lot of people are not aware of this so called trick and it may have never been fully understood, pre-sewed, or is in partial development and quite possiable, a forgotten feature.
I don't know, do you? -
22. Re: Need to change an object color to another...help
P Spier Aug 29, 2009 10:18 AM (in response to Mike Ornellas)No Idea. But if it used to work better, my tendency is to file the bug.
23. Re: Need to change an object color to another...help
Mike Ornellas Aug 29, 2009 10:31 AM (in response to P Spier)Hmm.
Well, bug reports are a one way communication. Not interested in that.
24. Re: Need to change an object color to another...help
P Spier Aug 29, 2009 5:35 PM (in response to Printer_Rick)OK Rick,
I see now how you are using the satin effect as basically a color overlay with a blending mode, and it works pretty well as long as the color you are trying to change doesn't have any significant black component, nor would I want to try to use a spot color. Pretty slick
What am I looking for with the ai file? I'm able to copy and paste the paths into ID just fine and they are completely editable. There is a differnce in how ID handles the Multiply mode from how Illustrator is doing it. Illy seems to be isolating the layers so you get the red in the center. ID won't do that, so you get a rich mud black, but nobody ever claimed that ID had all of the capabilities of Illustrator. It's possible, perhaps, though I didn't discover a way, that you can get ID to also isolate the cyan from the center overlap. You could certainly cut a hole in it there using the pathfinder, but that's inelegant and not easily edited later.
I think if you look at the other discussion you'll see I said something to the effect of the path would remain editable in ID to the extent that ID is able to edit paths. This does not mean you will always be able to copy/paste paths and get an exact reproduction of the art in Illustrator. It means you'll be able to copy paths much of the time and edit them in ID if you need to do so and can achieve the effect you are looking for. There are plenty of cases where this is not approproriate.
I would probably never, for example, copy art like the sample Mike posted the other day. It would be faster to just create it in ID (particularly for me becasue my Illustrator skills are pretty weak), or to place it if there was no editing required. I did what I did with the copy/paste just to show that it could be done and the paths and overprints could be manipulated directly in ID. Frankly, it was a pain in the neck. I had to do it in logical chunks to keep ID from wanting to paste as uneditable .eps because there were so many paths.
Peter
25. Re: Need to change an object color to another...help
Printer_Rick Aug 31, 2009 6:35 AM (in response to P Spier)P Spier wrote:
OK Rick,
The color overlay should work well for the OP, and there is absolutely no Photoshop intervention required (provided there are no spot colors, I'm assuming they're aren't any.)
The OP stated the Photoshop image is blue. So it is probably either RGB or CMYK. To change it to green in InDesign, it's a matter of applying the color overlay with a process green color.
If the image is in fact a spot color monotone in Photoshop (I seriously doubt it is, JPEG doesn't support spot colors), then it's just a matter of remapping the blue spot to a green spot in InDesign using the Ink Manager.
If the color had a heavy black component to start with, chances are it wouldn't look blue to start with. A color blend mode changes the blue to green and maintains the luminosity of the original file.
The problem with colorized one channel image is the swatch becomes the black point of the image. It's exactly what you want if the image needs to print as one spot color only. But if your output is CMYK or RGB, making the image monochrome stands to make the appearance washed out.
26. Re: Need to change an object color to another...help
Peter
My point with the AI file is that it's never a good idea to paste content from one app to another.
If you copy from AI, it means that you do in fact have AI. The AI content should always be linked content. By pasting you lose the original file integrity.
The only time I could see it being justified is if you were trying to convert AI data to ID data, to pass along to someone who didn't have Illustrator.
My example is 3 little boxes, nothing more, and the appearance does not carry over properly to InDesign. Yes the paths are editable and you can restore the appearance (provided you notice the appearance change). But the AI construct cannot be replicated in InDesign, because InDesign layers and Illustrator layers are two entirely different things.
Some people may disagree with me and say that content can be freely passed back and forth between AI and ID, but in my book it's no better than pasting Photoshop content. There are too many ways that things can go wrong. (It's about like AI "Save as Photoshop", what a train wreck that is...)
27. Re: Need to change an object color to another...help
Printer_Rick Aug 31, 2009 7:32 AM (in response to P Spier)I sort of see your point now about black component...
If the RGB or CMYK is a flat monochrome image, and the color of the image is dark (like a midnight blue) then color blend mode will produce a green that is too dark.
If that's the case for OP, then normal blend mode will simply fill all the non-transparent pixels with the swatch color, as in attached file.
colorized_RGB_monochrome.zip 155.4 K
28. Re: Need to change an object color to another...help
P Spier Aug 31, 2009 12:16 PM (in response to Printer_Rick)Rick,
Pasting has its place. If you want exact fidelity, placing is a better option, but if you just need a path from an AI file to use as a custom frame, for example, you can save the hassle of tying to draw it again in ID by using copy/paste, and you can't get that kind of functionality by placing.
You want to use the technique that works best for the task at hand. I actually just finished a press check on a job that I copied a few paths from Illustrator to create. I needed some marsh grass silhouettes, and it made more sense to use the paths as paths in ID and to resize and combine them in different ways and to experiment with the colors in the layout, than to keep going back to Illy to edit the image everytime I wanted to adjust something.
29. Re: Need to change an object color to another...help
Printer_Rick Aug 31, 2009 1:08 PM (in response to P Spier)I would agree with this. If you need to make edits to the art in InDesign, paste vector from AI is OK.
