CFHTTP/PayPal SetExpressCheckout Api
Enthusiast ,
Sep 02, 2009 Sep 02, 2009
I am slowly but surely getting to grips with PayPal integration. I am trying to connect to their SetExpressCheckout API
I have a CFHTTP set up as a GET (also tried post)
It manages to authenticate me, but as soon as I give the CFHTTP a NAME="test_paypal" for example along with DELIMITER="&", it gives me a problem.
It says that the first variable returned which is TOKEN is an invalid name, it looks like this is a reserved name in CF?
I see this and a few other variables that I need using CFHTTP.FILECONTENT
Is there another way to correctly read all the variables returned without running into this issue?
Btw Any developers out there interested in working on this for me please let me know, I'll be on this for a lifetime at this rate!
Mark
Advanced techniques
2.7K
Valorous Hero ,
What does the code look the that is throwing the error?
If it is, as I suspect, when you try to reference the variable and you are using 'dot' notation.  This can almost always be resovled by using 'array' notation.
I.E. if you are using something like payPal.token and it is throwing an error, you can get to the same data with payPal["token"].
Enthusiast ,
Hi Ian,
Here is the code, and the server response that I get. If I try to use NAME= , it just goes into invalid variable for TOKEN
<CFHTTP URL="#serverURL#" METHOD="post" THROWONERROR="YES" delimiter="&" >
<CFHTTPPARAM NAME="METHOD" VALUE="SetExpressCheckout" TYPE="FormField"
ENCODED="YES">
<CFHTTPPARAM NAME="USER" VALUE="#APIUserName#" TYPE="FormField" ENCODED="YES">
<CFHTTPPARAM NAME="PWD" VALUE="#APIPassword#" TYPE="FormField" ENCODED="YES">
<CFHTTPPARAM NAME="SIGNATURE" VALUE="#APISignature#" TYPE="FormField"
ENCODED="YES">
<CFHTTPPARAM NAME="VERSION" VALUE="#version#" TYPE="FormField" ENCODED="YES">
<CFHTTPPARAM NAME="AMT" VALUE="1.00" TYPE="FormField" ENCODED="YES">
<CFHTTPPARAM NAME="RETURNURL" VALUE="http://www.xxxxxxxxxxx.com/buy.cfm"
<CFHTTPPARAM NAME="CANCELURL" VALUE="http://www.xxxxxxxxxxxxxx.com"
</CFHTTP>
<CFOUTPUT>
#cfhttp.fileContent#
</CFOUTPUT>
server gives
TOKEN=EC%2d5HNxxxxxxxxxxxxxT&TIMESTAMP=2009%2d09%2d02T20%3a50%3a33Z&CORRELATIONID=52f09a0972424&ACK=Success&VERSION=59%2e0&BUILD=000000
Now if I add the NAME, I get
Error Occurred While Processing RequestThe web site you are  accessing has experienced an unexpected error.
Please contact the website  administrator.
The following information is meant for the website developer for  debugging purposes.
The column  name TOKEN=EC%2d5T01xxxxxxxxxx42G is invalid.
Column names must be valid variable  names. They must start with a letter and can only include letters, numbers, and  underscores.
The  error occurred in D:\ACS\paypal\index.cfm: line 27
25 : <CFHTTPPARAM NAME="RETURNURL" VALUE="http://www.xxxxxxxxxxx.com/buy.cfm" TYPE="FormField" ENCODED="YES">
26 :
27 : <CFHTTPPARAM NAME="CANCELURL" VALUE="http://www.xxxxxxxxxxx.com" TYPE="FormField" ENCODED="YES">
28 :
29 :
Valorous Hero ,
What do you mean by "Add Name"
Where are you adding a Name property and how are you trying to use it?
Enthusiast ,
I add a name to the CFHTTP so that I can treat it as a query, but that looks like the wrong approach for sure, that's when it throws the error
There is a CFC with the paypal example codes, but I can't run CFOBJECT on godaddy so that would be a problem, besides, can't get it to work right anyway (on local system)
Valorous Hero ,
I see and it looks like CF does not want to build a query record set with "result" as a column name.
I admit I have never ran into that, but it is possible.
It should not be to hard to manually parse that data into a record set or some other data construciton with a loop.
<cfset payPalStruct = structNew()>
<cfloop list="#cfhttp.fileContent#" index="elem" delimiter="&">
<cfset payPalStruct[listFirst(elem,"=")] = listLast(elem,"=")>
</cfloop>
<cfdump var="#payPalStruct#">
Enthusiast ,
great, it works
Below are the results (btw I had to change delimiter to delimiterS, plural.
I used #paypalstruct.token# and it did the trick.
that's great, I've been killing myself for way too many hours over this.
(Out of interest do you do sub work incase I need further assistance on this or other CF projects that I am involved in)
struct
ACKSuccess
BUILD000000
CORRELATIONID6b80xxxxxxxx3be
TIMESTAMP2009%2d09%2d02T21%3a29%3a30Z
TOKENEC%2d1Rxxxxxxxxxxxxx7001B
VERSION59%2e0
Valorous Hero ,
great, it works
Glad to hear it.
Yes, it is always prudent to double check syntax.
Occasionally, but I am not available for much for the next few weeks.
http://www.ilsweb.com
Documentation
