As I create the index, everything looks normal. When I view the compiled product (WebHelp) the Index and Search tabs are there, but when I click them, nothing happens. Nothing shows in the pane. When I put the cursor in the field, it just flickers, and whatever I type will not show in the search field. When I compile to MS HTML Help (.chm) both features work fine. I have a feeling something is corrupted, but I don't know which program-generated files are safe to delete. My browser is IE 6.0.2900. This behavior is the same whether it is on my computer in development mode, or loaded in the application I support.
The graphic pasted here is what I see when opening the product. Can anyone help me with this?
Try generating to a new folder.
If that fails create a new layout, not a duplicate.
Otherwise I thought this was covered recently so try a search if this doesn't help.
Let us know how that goes.
Peter, thank you for your prompt reply.
I tried compiling to a different folder, and that had no affect.
I compiled to a .chm and it worked fine. I have to use the WebHelp layout though.
I'll keep looking in the list of questions, but I found very few that referenced RH x5.
Thanks.
Becky
You don't say that you have tried creating a new layout for webhelp. Not a duplicate.
Right click in the layouts pod.
I tried both of your suggestions and neither worked. I just created a new project and imported the .htm's and it works fine now.
Becky Williams
Instructional Design, IT Systems Training | AT&T Services | 1125 E Campbell Rd | Richardson, TX 75080 | O: 972.952.8638 | M: 972.989.9155 | RW4124@att.com
(This message, including any attachments, is the property of and contains confidential information of AT&T Mobility. If you are not the intended recipient, please notify the sender of the error and delete this message and any attachments.)
Obviously something got corrupted but you're OK now.
Take a look at Before You Post re including your email address. Let me know if you want it removed.
