can i disable the next defult butoon in specific slide that the user cant press on him?
Is this what you are trying to do?
http://www.raisingaimee.co.uk/temp/hideshowdemo.htm
I have made two AS2 widgets one to hide the button the other to show it again
Insert the hide widget on frame you want to hide the next button, then use the show widget on the frame you wish it to re appear
download hideshownextbutton.zip from here http://www.raisingaimee.co.uk/temp/
Paul
Hello,
Your question is not quite clear to me. Are you talking about the playbar, because on the slide normally you do not have a 'next button'. And which version of Captivate are you on?
Lilybiri
Perhaps some wise guy has an idea how to achieve this, but I'm afraid that this is not that easy. The playbar is part of the skin, and is added in the published movie, at runtime. You cannot control the playbar in a different way, depending on the slide playing. It is all or nothing: removing a button will be so for the whole movie.
However, instead of using the playbar for the navigation, you can add one (or more) buttons on the slides themselves, and control the navigation that way. Than it will be possible to remove buttons on specific slides. If you want to try this workaround?
Lilybiri
yes i thought about that to do my own control bar
i put slides in the end of my project that u can go to them from anoter slides and when u get to the end slide if u press next button u wiil get to them
i think maybe i can do java action on the slide or somthing
thank for your answere
Paul
thank u
u save my project
u have also back widget?
Just made you one to hide / show back button download from same place and use same way as others
thnx
Hey Paul,
I would love to get my hands on this with AS3! I am trying to disable the next/forward button until the learner answers a question/performs the interaction on a given slide. Right now I found a solution that is not the best one, I am hiding the playbar on page enter and show after interaction completed/question answered. My preferred solution would be to simply disable the next button and not the whole playbar.
