Context Sensitive Help and bookmarks / anchors in Robohelp 7
Dec 06, 2008 Dec 06, 2008
How can I use the F1 Help and bookmarks / anchors in Robohelp 7?
1: Topic with referrer in the HEAD section.
<head>
<meta http-equiv="refresh" content="0; URL=examle.htm#anchor">
</head>
Works flawlessly in the preview but not in the compiled CHM File.
2: Javascript:
see attached code
Works nicely. But what about platfoms with javascript disabled? However, it's not elegant to use a couple of referrer topics.
3: Change the ALI File
The ALI Files is where Robohelp saves IDs-Topics references.
Just change the URL from NAME OF ID=\example.htm to NAME OF ID=\example.htm#anchor and add <a name="anchor"></a> to your code in the topic file.
Nice, clean and easy - if you know where to find the information you need.
Mike
564
Engaged ,
Dec 08, 2008 Dec 08, 2008
Mike,
I think you are making this more complicated than need be. F1 help should be connected by the software developer such that F1 produces a map number. You can read this number by firing F1 when RoboHelp's BugHunter is enabled. BugHunter will report that map number.
To connect to help, you have two files - the .hh (help header, but can also be just .h) and the .ali file. The format should be
in hh file: #define MAPID 123456
where MAPID is anything, usually a descriptive map name, and 123456 is the map number you get from F1.
in .ali file: MAPID="topicname.htm#bookmark"
I usually create the .hh and .ali files outside of RoboHelp but you can do this in RoboHelp.
If BugHunter does not give you a map number, you need to talk to the developers.
John
RoboHelp Documentation
Download Adobe RoboHelp
