I'm working in RoboHelp v7 and when I go to generate my CHM Files to a folder on my D Drive I get the above Fatal Error.
I have recreated the folder and path where the generated CHM files are to be created and this seemed to fix the problem for one publish, but now it is back.
I have found a work around which allows me to publish which is removing some spaces from the file name of the CHM files that are generated.
Any help is muchly appreciated even though I have a work around I still need to find a solution to this problem.
Kristy
I should add, D drive is my local drive on my workstation.
You have a project with a name that has a space in it and you have not updated RoboHelp with the patches. Correct?
Spaces are best avoided but the patches did fix this.
Yes we do have a project name with spaces in it and have not updated RoboHelp any patches.
Would you suggest patching RoboHelp to the lastest version of RoboHelp 7?
Given they fix the problem and other problems, yes. You should always install the patches when released.
BTW. You have to install all three in order. Go to the Help menu and you will see the Update option.
When attempting to look at what patches need to be applied I went under Help and Update was greyed out. Would this be because we don't have these enabled - to be able to apply patches?
Note:Because of the secure environment we work in applying patches is kept to a limited amount.
I would also like to mention that your help has been muchly appreciated
My guess is that you don't have admin rights. You will need to get your IT people to log in and install them. No reported issues seen on the forums as a result of installing these patches other than one RoboHelp for Word problem so that will not affect you.
