Can anyone help?
I have imported an audio file and have modified the position of the slide markers in the edit window so that it plays accross several slides as background music. Each time a slide changes the music drops out for a split second and then resumes.........pants!
Cheers
Sam
Are you running 7.0.5? Try upgrading and see if it fixes the issue.
Patch is available here;
http://www.adobe.com/support/downloads/product.jsp?product=153&platform=Windows
matt rock | Technical Response Team, Connect | adobe systems
Thanks for your quick response
...I've run the patch (up to vs 7.05) however the problem is still there, the audio drops out as each slide changes (chops out and back very quickly) Any more ideas welcome!
Ta
Sam
Can you try using the PPT format instead of PPTX? Or vice versa, to see if the problem goes away?
You can try the following
Many thanks for the tips, the first looks like a good idea, although I'm keen to find out why the software doesn't basically 'do what it says on the tin' in terms of playing audio accross slides as it should
Cheers!
Sam
Sorry...I don't know how to do this
