I was playing around with my project's default skin and after
I saved I saw a message appear near the bottom of the screen that
said "Applying skin...". It went through and updated all of my
topics with the new settings. I then wanted to revert the changes
back again because I didn't like the result, but it didn't re-apply
the changes again after I saved. I have tried restarting RH,
reloading topics and the only way it appears that I can resolve it
is to go into the topic properties, remove the skin and reapply it.
This is very time consuming in such a large project!
I was wondering if anyone knows a way to manually ask RH7 to
apply a skin to all / many topics at once?
Amebr-ke0mH4 • Contributor, Dec 08, 2008Dec 08, 2008
If you change to the Topics tab (right hand side in RH6) then
you can select multiple topics using the normal windows Ctrl and
Shift options. Right-click and select Properties, and on the
General tab you can select a template which will be applied to all
selected topics.
HTH
selected topics.
HTH
