Hello everybody.
This is LCES 8.2.1 SP2 running on Windows 2003 server (turnkey).
Today I gave the executeScript a try but it seems the setProcessDataListValue causes Jboss to use 100% of the available CPU cycles and has to be stopped.
Here's the script I'm using:
=== cut here === 8<===
import java.util.List;
import java.util.Iterator;
import com.adobe.idp.Document;
List attachList = patExecContext.getProcessDataListValue("/process_data/doclist");
List newList = patExecContext.getProcessDataListValue("/process_data/doclisttask");
newList.clear();
Iterator it = attachList.iterator();
while(it.hasNext()) {
Document attDoc = (Document) it.next();
String name = (String) attDoc.getAttribute("name");
attDoc.setAttribute("wsfilename",name);
newList.add(attDoc);
attachList.clear();
patExecContext.setProcessDataListValue("/process_data/doclisttask",newList);
In WorkBench, both doclist and doclisttask have Type=list and SubType=document.
By putting some System.out.println into the above script I've been able to verify that the process seems to hang while executing the patExecContext.setProcessDataListValue("/process_data/doclisttask",newList); before getting to the last line, I've been also able to check that "name" (String) is set correctly and that newList.add(attDoc) does return true (doclist has 2 document).
At this point, Jboss does consume all the available CPU and I have to manually stop it; I checked against Jboss log file but no error messages and or exceptions are reported.
What am I missing?
Rob
Total Likes
Problem solved.
It turned out that you do not need to "import" a LCES variable if you plan to initialize it into the script.
At the benefit of future posters/seekers, here's the script which works:
=== cut here === 8< ===
List newList = new ArrayList();
if (newList.add((Document)attDoc) != true) {
System.out.println("Error while inserting!");
Cheers,
Rob
Total Likes
