Error:
Error casting an object of type to an incompatible type. This usually indicates a programming error in Java, although it could also mean you have tried to use a foreign object in a different way than it was designed.
The error occurred in C:\Inetpub\wwwroot\RMS\Untitled-3.cfm: line 15 | |
13 : <cfloop from="1" to ="#listlen(application.Sql_SC)#" index="i"> 14 : union 15 : <cfquery name="GetZone#i#" datasource="#i#"> 16 : SELECT ccflocationID, Location_Name 17 : FROM ccflocation |
<cfcomponent hint="This cfc goes to Scorecard environment and grabs some stuff">
<cffunction name="Zone" access="public" returntype="Query">
<cfset myLoc = QueryNew("ccflocationID,Location_Name", "Integer,VarChar")>
<cfargument name="DSN" required="true" type="string">
<cfquery dbtype="query" name="GetZone">
select ccflocationID, Location_Name from myLoc
<cfloop from="1" to ="#listlen(arguments.DSN)#" index="i">
union
FROM ccflocation
</cfquery>
</cfloop>
</cfquery>
<cfreturn GetZone>
</cffunction>
</cfcomponent>
You are trying to ignoring what I told you in the other thread and attempting to combine Q of Q and database queries. You have to do them separately.
I am not ignoring you Dan, I followed your recipe and ends up here... what else not in place???
See my reply in the other thread you raised about this problem.
Adam
You can NOT mix QoQ and DB queries together...
this is QoQ
this is DB query
You will need to run your DB queries first (outside QoQ)
and then run the loop again to UNION all results...
FROM ccflocation
</cfquery>
</cfloop>
union
select ccflocationID, Location_Name from GetZone#i#
</cfloop>
</cfquery>
