Show 1 reply
1. Re: What is the best way to move a LR2 catelog without moving the images?
djabel61 Sep 8, 2009 5:24 PM (in response to DVDmike)Mike,
I have moved the catalog files numerous times without trouble. I would suggest that you copy the Catalog Folder and all of its contents to the new drive, without deleting the original. Make sure Lightroom is not running when you do this. Then open Lightroom while holding down the OPTION key, and you will be presented with a pop-up allowing you to select the catalog file in the new location. Once you select it, Lightroom should operate as before.
Then go ahead and delete the previous catalog folder.
