Hi all, just wondering if its possible to batch create snippets from a heap of topics. I've got a lot of topics that I want to create snippets from for single source purposes and having to add them to the snippet library one by one is becoming teadous. Just wondering if it can be done, evena drag and drop or something would speed things up.....
another quick thing, once I've create these snippets (from topics), the original topic that they were made from is now totally redundant isn't it? meaning I can delete it, I can see any relationship between the 2.
These are only snippets made from an entire topic.
Hi there
I'm unclear on how snippets will help here. Please advise us on exactly how this topic you wish to change to a snippet currently works. Are you inserting it using inline frames or what?
I'm failing to see why you would want to change an entire topic to a snippet.
Indeed if you had the topic content as a snippet you would be able to delete the topic as the data is now inside the snippet.
Snippets are used to insert repetitive text into certain areas of other topics.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 within the day - $24.95! |
I have a lot of topics that were created based on heading levels that dont need to have their own headings, or topics, they maybe explain a section with only 2 or 3 sentences and need to be embedded in another topic and some outputs need all of these small topics, and some don't, so I need to make them into snippets but there are quite a few. Looks like manually doing it is the only way though. Thats something you cant do in RH is it, multi-select topics in the Project Manager view.
thanks though, I will create my snippets and delete the topics.
Hi there
Yes, you are correct in saying you cannot multiple select topics in the Project Manager view.
But you can in the Topic List pod.
Cheers... Rick
