how can i do that my project will continue when i press on the mouse? (like when i move the line on the play bar)
Hi there
One way is to insert a Click Box object. Size and position as needed.
Cheers... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
it doesnt help me becouse i dont pause the project i have sentence that apper one ofter another and i want that with clik on the mouse the sentence will apper and the user dont wait for them to apper
Hi there
I'm not sure I follow. So you want the project to just sail along without pausing? If so, why not simply stage captions to appear at specific timed intervals?
To request a mouse click you must use some object that is clickable. The most likely candidate here is the Click Box as it is invisible.
Cheers... Rick
Hi there
First, forums 101. If you have an image you want us to see, never Never NEVER use the attach function. Instead, use the camera icon above where you type your post.
I'm thinking you could accomplish your goal by doing the following. Configure multiple slides with each slide having the bullet text. Time them as you wish so they look appropriate. Then insert a Click Box object on each of the slides. The action would be "Go to next slide" when the user clicks. You would also remove the pause from each of them.
The net result should be that things seem to flow along without pausing. But if the user clicks, the next bullet appears instantly because the next slide appears.
Cheers... Rick
