1. Re: CRASH - linking from the properties panel
dan_hin Sep 9, 2009 3:37 PM (in response to dan_hin)bump
2. Re: CRASH - linking from the properties panel
Bill Hunt Sep 9, 2009 3:51 PM (in response to dan_hin)Now, I do not have CS3, but En 2.0, so this does not address your problem, but over the years, many hundreds of Projects and nearly 2000 DVD's burned, I have had zero crashes and only one error message. I do not recall many commenting on instability with CS3, though there do seem to be more with CS4.
With crashes, the troubleshooting almost always breaks out this way, and in this order:
1.) System
2.) Assets
3.) Project
This is slightly different in En, than in PrPro. There, the Project is usually at #2 and the Assets #3, though not always.
If you can give the full details of your system, the more the better, your Assets and your Project, there might be something in there that will point to the problems. Again, the more detail, the better.
Also, when one has program, or system crashes, there are often clues scattered around. This ARTICLE might help you find a few of those clues.
Good luck, and I hope that someone can see the problem quickly for you,
Hunt
