Using RoboHelp 7 HTML.
I am single sourcing to several outputs, one of which needs to have this width increased as it appears on the device (iPhone) too small to make out the icons or text.
There is a workround in Skinny on Skins, but it requires replacing a file every time the project is generated as it gets overwritten. Before I try this method, I wanted to find out if there is a better way of doing this.
City Sue
Hi there
With RoboHelp the skins files all have "seed" files that are stored where the install folder for RoboHelp is. If you modify the seed file it should then propagate to the output without your having to modify each time.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 within the day - $24.95! |
Hi Rick,
this is on the right track but I should give a little more background.
My questions now are:
Where is the seed file? Does it have a .skn extension? Would the path be something like C:\Program Files\Adobe\Adobe RoboHelp 7\RoboHELP\sqSkinsExt\XslFiles
This is scarey stuff for me Rick! Maybe, while I wait for your response, I will try out the fix you describe in Skinny.
