I would like to add a button on the bottom of each slide that users can click to move to the next slide and also a button to return to previous slide. I am really new to this program and would appreciate any help.
Hi there
Sorry, but my crystal ball seems to be broken today. I can't tell what version of Captivate you are using!
On the outside chance you are using version 4, try pressing Ctrl+Alt+Z and you should see a panel open that is labeled Widgets. Inside that panel is a widget you might use. It's called Perpetual Buttons. Edit Slide 1 and click and drag that widget to your slide. Configure it to run the rest of the movie and position as desired.
Cheers... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
Oh yeah, I am using version 4. Thanks for your help and fast response!
