1
Export Groups to Files?
Sep 06, 2009 Sep 06, 2009
Is there a way to export multiple GROUPS into individual files, such as jpg?  If I run the File > Scripts > Export LAYERS To Files, each LAYER becomes a jpeg, but i'd like each GROUP to be flattened and exported as a jpg. Is there a script or funtion that performs this task?
Actions and scripting
115.5K
correct answers 2 Correct answers
Community Expert , Sep 08, 2009 Sep 08, 2009
You could try attached Script, You’d have to adapt it to jpg, currently it saves pdfs.
I have not tested it very extensively and only in CS4 though.
// creates pdf-copies of layersets with dialog to select layers and suffix;
// be advised: existing files of identical names will be overwritten without warnings;
// 2009, pfaffenbichler, use it at your own risk;
#target photoshop
if (app.documents.length > 0) {
// get document-path and -title;
	var myDocument =
Community Expert , Sep 09, 2009 Sep 09, 2009
You could replace the pdfOptions with
var jpgopts = new JPEGSaveOptions();
jpgopts.embedColorProfile = true;
jpgopts.formatOptions = FormatOptions.STANDARDBASELINE;
jpgopts.matte = MatteType.NONE;
jpgopts.quality = 10;
and edit that according to Your needs.
Then replace »pdfOpts« and ».pdf« in the saveAs-line with »jpgopts« and ».jpg«.
Adobe
Sep 07, 2009 Sep 07, 2009
Are all the groups on the topmost hierarchical level or are there groups within groups?
#target photoshop
	var myDocument = app.activeDocument;
	var myDocName = myDocument.name.match(/(.*)\.[^\.]+$/)[1];
	var myPath = myDocument.path;
	var theLayerSets = collectLayerSets(myDocument);
////// filter for checking if entry is numeric, thanks to xbytor //////
	numberKeystrokeFilter = function() {
	this.text = this.text.replace(",", "");
	this.text = this.text.replace(".", "");
	if (this.text.match(/[^\-\.\d]/)) {
		this.text = this.text.replace(/[^\-\.\d]/g, "");
	if (this.text == "") {
		this.text = "0"
// create the dialog;
	var dlg = new Window('dialog', "pdfs from layersets", [500,300,930,840]);
//create list for layer-selection;
	dlg.layerRange = dlg.add('panel', [21,20,279,445], "select layersets to create pdfs of");
	dlg.layerRange.layersList = dlg.layerRange.add('listbox', [11,20,240,405], '', {multiselect: true});
	for (var q = 0; q < theLayerSets.length; q++) {
		dlg.layerRange.layersList.add ("item", theLayerSets[q].name);
		dlg.layerRange.layersList.items[q].selected = true
// entry for suffix;
	dlg.suffix = dlg.add('panel', [290,20,410,85], "enter suffix");
	dlg.suffix.suffixText = dlg.suffix.add('edittext', [11,20,99,40], "", {multiline:false});
// entry for number;
	dlg.number = dlg.add('panel', [290,100,410,165], "start with #");
	dlg.number.startNumber = dlg.number.add('edittext', [11,20,45,40], "1", {multiline:false});
	dlg.number.addNumber = dlg.number.add('checkbox', [55,20,105,40], "add", {multiline:false});
	dlg.number.startNumber.onChange = numberKeystrokeFilter;
// field to add layer-name;
	dlg.layerName = dlg.add('panel', [290,180,410,270], "layer-name");
	dlg.layerName.doAddName = dlg.layerName.add('radiobutton', [11,20,120,40], "add it");
	dlg.layerName.dontAddName = dlg.layerName.add('radiobutton', [11,45,120,65], "don’t add it");
	dlg.layerName.doAddName.value = true;
// field to select target-folder;
	dlg.target = dlg.add('panel', [290,285,410,445], "target-folder");
	dlg.target.targetSel = dlg.target.add('button', [11,20,100,40], "select");
	dlg.target.targetField = dlg.target.add('statictext', [11,50,100,155], String(myPath), {multiline:true});
	dlg.target.targetSel.onClick = function () {
		var target = Folder.selectDialog("select a target folder");
		dlg.target.targetField.text = target.fsName
// ok- and cancel-buttons;
	dlg.buildBtn = dlg.add('button', [220,460,410,475], 'OK', {name:'ok'});
	dlg.cancelBtn = dlg.add('button', [21,460,210,475], 'Cancel', {name:'cancel'});
	dlg.warning = dlg.add('statictext', [21,490,410,530], "be advised: existing files of the same name will be replaced without prompting", {multiline: true});
	dlg.center();
	var myReturn = dlg.show ();
// in case of OK;
	if (myReturn == true && dlg.layerRange.layersList.selection.length > 0) {
// get the number instead of the name;
		var theLayerSelection = new Array;
		var theColl = dlg.layerRange.layersList.items;
		for (var p = 0; p < dlg.layerRange.layersList.items.length; p++) {
			if (dlg.layerRange.layersList.items[p].selected == true) {
				theLayerSelection = theLayerSelection.concat(p);
// collect the rest of the variables,
		var theSuffix = dlg.suffix.suffixText.text;
		var theNumber = Number (dlg.number.startNumber.text) - 1;
		var theLayerNameAdd = dlg.layerName.doAddName.value;
		var theDestination = dlg.target.targetField.text;
		var theNumbering = dlg.number.addNumber.value;
// pdf options
		pdfOpts = new PDFSaveOptions() ;
		pdfOpts.embedColorProfile = true;
		pdfOpts.PDFCompatibility =  PDFCompatibility.PDF13;
		pdfOpts.downSample =  PDFResample.NONE;
		pdfOpts.vectorData = true;
		pdfOpts.alphaChannels = false;
		pdfOpts.byteOrder = ByteOrder.MACOS;
		pdfOpts.layers = false ;
		pdfOpts.preserveEditing = false ;
		pdfOpts.convertToEightBit = true;
		pdfOpts.annotations = false;
		pdfOpts.colorConversion = false;
		pdfOpts.embedFonts = true;
		pdfOpts.embedThumbnail = true;
		pdfOpts.transparency = false;
		pdfOpts.encoding = PDFEncoding.PDFZIP ;
		var theVisibilities = new Array;
// create the pdf-name;
		if (theSuffix.length > 0) {
			var aSuffix = "_" + theSuffix
		else {
			var aSuffix = ""
// create a flattened copy;
		var theCopy = myDocument.duplicate("thecopy", true);
// do the operation;
		for (var m = theLayerSelection.length - 1; m >= 0; m--) {
			app.activeDocument = myDocument;
			var theLayer = theLayerSets[theLayerSelection[m]];
			if (theNumbering == true) {
				theNumber = bufferNumberWithZeros((Number (theNumber) + 1), 2);
				theNumberString =  "_" + theNumber
			else {
				theNumberString = ""
// get the layername for the pdf-name;
			if (theLayerNameAdd == true) {
				var aLayerName = "_" + theLayer.name.replace("/", "_")
			else {
				var aLayerName = ""
// transfer layerset over to the copy;
			theLayer.duplicate (theCopy, ElementPlacement.PLACEATBEGINNING);
			app.activeDocument = theCopy;
// hide the llast added layer;
			theCopy.layers[1].visible = false;
			theCopy.saveAs((new File(theDestination+"/"+myDocName+aSuffix+aLayerName+theNumberString+".pdf")),pdfOpts,true)
		theCopy.close(SaveOptions.DONOTSAVECHANGES);
else {alert ("no document open")};
////// buffer number with zeros //////
function bufferNumberWithZeros (number, places) {
	var theNumberString = String(number);
	for (var o = 0; o < (places - String(number).length); o++) {
		theNumberString = String("0" + theNumberString)
	return theNumberString
////// function collect all layersets //////
function collectLayerSets (theParent) {
	if (!allLayerSets) {
		var allLayerSets = new Array}
	else {};
	for (var m = theParent.layers.length - 1; m >= 0;m--) {
		var theLayer = theParent.layers[m];
// apply the function to layersets;
		if (theLayer.typename == "ArtLayer") {
		//	allLayerSets = allLayerSets.concat(theLayer)
		else {
// this line includes the layer groups;
			allLayerSets = allLayerSets.concat(theLayer);
			allLayerSets = allLayerSets.concat(collectLayerSets(theLayer))
	return allLayerSets
Yes, the Groups are all at the top level, and YES! your script worked wonderfully!  I'll need to figure out the jpg instead of pdf portion, but you definitely solved the difficult part. Thank you!!
Mar 16, 2010 Mar 16, 2010
Great skript!
Is there a way to export Groups to png?
Jun 08, 2010 Jun 08, 2010
Groups to .png is what I*m searching for, too.
Any ideas? Anyone?
Valorous Hero ,
You could try this..
#target photoshop
function main(){
if(!documents.length) return;
var doc = activeDocument;
var oldPath = activeDocument.path;
for(var a=0;a<doc.layerSets.length;a++){
activeDocument.activeLayer = activeDocument.layers.getByName(doc.layerSets.name);
dupLayers();
var saveFile= File(oldPath +"/"+doc.layerSets
.name +".png");
SavePNG(saveFile);
app.activeDocument.close(SaveOptions.DONOTSAVECHANGES);
main()...
function dupLayers() {
    var desc143 = new ActionDescriptor();
        var ref73 = new ActionReference();
        ref73.putClass( charIDToTypeID('Dcmn') );
    desc143.putReference( charIDToTypeID('null'), ref73 );
    desc143.putString( charIDToTypeID('Nm  '), activeDocument.activeLayer.name );
        var ref74 = new ActionReference();
        ref74.putEnumerated( charIDToTypeID('Lyr '), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
    desc143.putReference( charIDToTypeID('Usng'), ref74 );
    executeAction( charIDToTypeID('Mk  '), desc143, DialogModes.NO );
function SavePNG(saveFile){
    pngSaveOptions = new PNGSaveOptions();
    pngSaveOptions.embedColorProfile = true;
    pngSaveOptions.formatOptions = FormatOptions.STANDARDBASELINE;
    pngSaveOptions.matte = MatteType.NONE;
pngSaveOptions.PNG8 = false;
    pngSaveOptions.transparency = true;
activeDocument.saveAs(saveFile, pngSaveOptions, true, Extension.LOWERCASE);
Jun 10, 2010 Jun 10, 2010
Great script Paul!
I've added
     activeDocument.trim(TrimType.TRANSPARENT,true,true,true,true);
before
so the PNG files are trimmed before saving.
Sep 29, 2010 Sep 29, 2010
Paul, This looks like a life saver script to me, but I am having a problem.
When I run it, it asks to save each group/file as a PSD.
I am an old time programmer, so I get the logic, but I don't know any of the syntax of photoshop scripting.
If i did I would try to sort this out myself.
Is there some overriding setting in preferences I need to change that won't just allow the script to save the group as a PNG (without my interaction) as the script seems to be telling it to do?
Thank you SO much.
Ed
Valorous Hero ,
There were a fewmistakes in that code, could you please try this now...
#target photoshop
function main(){
dupLayers();
activeDocument.mergeVisibleLayers();
activeDocument.trim(TrimType.TRANSPARENT,true...
.name +".png");
SavePNG(saveFile);
main()...
var pngOpts = new ExportOptionsSaveForWeb;
pngOpts.PNG8 = false;
pngOpts.transparency = true;
pngOpts.interlaced = false;
pngOpts.quality = 100;
activeDocument.exportDocument(new File(saveFile),ExportType.SAVEFORWEB,pngOpts);
Sep 14, 2011 Sep 14, 2011
if you guys are still around, and can help I would love it. Exact same problems and needs to everyone here above. I have NO knowledge of editing scrips. The one for PDF worked but as you know really time consuming to then convert PDF to JPEGS. Can someone provide me the the script to download which works for converting the layer groups to .jpeg.
I would very very much appreciate it. I tried to edit the code for the script but very shamefull unsuccessful
Thank you
Sep 15, 2011 Sep 15, 2011
The Script from which post are you referring to exactly?
Valorous Hero ,
Have you tried this one?
Layer Saver
This supports jpeg
You are an absolute legend. Thanks mate. You saved my life. thanks thanks thanks
Dec 21, 2011 Dec 21, 2011
Fantastic script!  Is there a way to have this script combine the exported JPG's or PDF's into a single PDF?
Valorous Hero ,
Sorry but the option of creating multipage PDFs was removed in Photoshop CS4 and that functionality was moved to Bridge and that process is not scriptable.
So if you have Photoshop CS2 or CS3 you could open all the JPGs and use File - Automate - PDF Presentation to create your pdf.
Nov 28, 2013 Nov 28, 2013
Hi Paul,
The link is down, can you upload it again?
This script 'd really save me some valuable time
Engaged ,
try this, the layer saver is towards the bottom of the list:
http://www.ps-bridge-scripts.talktalk.net/
Paul makes some very useful scripts, thanks!
Alas, if I remember correctly he stopped participating in these Fora because of his frustration with Adobe’s bug fixing neglect.
Sep 28, 2018 Sep 28, 2018
Could you please help me to Export Artboards PNG and Ai?
Nov 13, 2018 Nov 13, 2018
Thanks a lot for this script! It helps me and automate my routine work !!!
Does the script make all other layers invisible when export the current group? May I change it? I need some layers that I choose visible stay visible during exporting groups. For example I made a storyboard. And it has in the bottom unchangeable bg white colors and a picture borders - white rectangle with black stroke, and in each group I draw frames, and in each group there aren't bg and picture borders. I switch off visibility of groups, but bg and borders are always visible. To see them on each jpg I should to copy and paste them in each group. Can I avoid it with your script?
Nov 25, 2018 Nov 25, 2018
Which exact Script are you referring to?
Could you post a screenshot of the file’s Layers Panel to illustrate the Layer structure and clarify which Layers you want to »fixate«?
Apr 24, 2015 Apr 24, 2015
Hello,
I'm looking to do the same (export all top level groups as images). Is there an updated script that works in CC?
Apr 26, 2015 Apr 26, 2015
Doe the Script fail for you in CC and if so how exactly?
