streaming .swf?
Guest
Sep 08, 2009 Sep 08, 2009
hi
i am creating fairly long videos which i am exportng to swf using the FTP export option. the problem is that the swf files are very large and when i view the .swf's in the browser i noticed that the entire file needs to be downloaded first which can take anywhere up to 10 minutes before it will start playing. is there an export option where i can create a file that will stream in realtime for my users?
cheers
angus
Import export
1.5K
Advisor ,
Sep 09, 2009 Sep 09, 2009
Are you using Captivate at all?
Why are you exporting your videos to SWF? If they are videos then you should keep them as FLV's as they allow progressive download. To my knowledge SWF's cannot be streamed.
/Michael
Guest
Sep 12, 2009 Sep 12, 2009
Hi
Yes I am using captivate. I do not see a .flv export option anywhere - only .swf
Hi there
Captivate cannot export as FLV. I think because you mentioned you were creating videos, Michael may have assumed you meant lots of full motion movie type videos and not Captivate videos.
Cheers... Rick
Helpful and Handy Links
Captivate Wish Form/Bug Reporting Form
Adobe Certified Captivate Training
SorcerStone Blog
Captivate eBooks
Guest
Ok great thanks for the info...
Sep 15, 2009 Sep 15, 2009
While it is not really streaming....In the publishing options I would select a preloader and set the percentage to a lower number than 100%.
This is found in the Project Perferences...Project...Start and End.  This is where you can select a preloader and the percentage to begin at.
As long as you have a linerar video (no massive jumping between slides) and your download rate is pretty consistent you could set this to like 50%.  Which means the video will start playing after 50% load.  You just want to make sure that your playing video does not catch up to the the downloaded portion.  If it does it will pause and resume once that portion has been downloaded.
You will need to try several settings to get the right one but I think you might find that this might help get your video started sooner than waiting for 100% to be loaded.
Help resources
