Total Likes
Total Likes
Total Likes
quote:
Originally posted by:
sharedvision
I'm still unable to get the flex data samples working in
WebSphere V6...
Here is the relevant element from web.xml...
<resource-ref>
<description>Flex Messaging
WorkManager</description>
<res-ref-name>wm/MessagingWorkManager</res-ref-name>
<res-type>com.ibm.websphere.asynchbeans.WorkManager</res-type>
<res-auth>Container</res-auth>
<res-sharing-scope>Shareable</res-sharing-scope>
</resource-ref>
When I go to the admin console, I do not see a link for the
war file under Enterprise Applications, I see the Enterprise
Application I published the war file to. I've looked for the link
Cathy referred to, to validate the mapping ("Additional
Properties|Mapping resource refs to resources"), but it doesn't
exist in my environment. I am publishing the samples in Rational
Application Developer V6.0.1.1 with WAS 6.0.2.5.
sharedvision
flex-enterprise-services.xml...
<channel-definition id="my-rtmp"
class="mx.messaging.channels.RTMPChannel">
<endpoint uri="rtmp://{server.name}:2037"
class="flex.messaging.endpoints.RTMPEndpoint"/>
<properties>
<idle-timeout-minutes>20</idle-timeout-minutes>
<!-- for deployment on WebSphere, must be mapped to a
WorkManager available in the web application's jndi context. -->
<websphere-workmanager-jndi-name>java:comp/env/wm/default</websphere-workmanager-jndi-name>
</properties>
</channel-definition>
I am happy to use the default workmanager. I guess I don't
see where the mapping occurs between what is in the web.xml and the
flex-enterprise-services.xml files.
Total Likes
