Revision: 10218
Author: gruehle@adobe.com
Date: 2009-09-13 11:03:38 -0700 (Sun, 13 Sep 2009)
Log Message:
Fix more skinning and styling bugs.
SDK-23161 ?\226?\128?\147 Halo VideoDisplay now has a white background instead of old black background.
add contentBackgroundColor style to VideoDisplay selector. Still need backgroundColor style, so that one is not removed.
SDK-23122 ?\226?\128?\147 ApplicationControlBar looks different.
set borderSkin for ApplicationControlBar to the HaloBorder. This brings back the Halo look for ACB (there is no Spark look specified by XD)
SDK-23115 ?\226?\128?\147 Halo Panel dropShadow displayed in closed divided box.
hide the drop shadow if the panel width or height is 0
SDK-22551 ?\226?\128?\147 Background is not a gradient when compiling a Flex 3 app with Flex 4 and using the Halo theme.
add ApplicationBackground to sparkskins, and removed Flex 4 specfic code from the Halo ApplicationBackground. The spark ApplicationBackground just draws a rect using backgroundColor. I tried removing it completely (why have an image drawing a solid color on top of the stage that is already that same color?), but that broke hundreds of bitmap comparisons. Apparently not all white pixels are created the same...
QE notes: None
Doc notes: None
Bugs: SDK-23161, SDK-23122, SDK-23115, SDK-22551
Reviewer: Corey
Tests run: checkintests, qe cyclone
Is noteworthy for integration: No
Ticket Links:
http://bugs.adobe.com/jira/browse/SDK-23161
http://bugs.adobe.com/jira/browse/SDK-23122
http://bugs.adobe.com/jira/browse/SDK-23115
http://bugs.adobe.com/jira/browse/SDK-22551
Modified Paths:
flex/sdk/trunk/frameworks/projects/framework/defaults.css
flex/sdk/trunk/frameworks/projects/sparkskins/src/SparkSkinsClasses.as
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/PanelBorderSkin.mxml
Added Paths:
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ApplicationBackground.as
