1. Re: (CS3) Is the "rangeName" property of Application.ExcelImportPreference really broken?
AdobeScripts Sep 11, 2009 3:58 PM (in response to Mike.Edel)hi
yeah, InDesign don't store full info about ImportPreferences with placed object - but should do this and use it later ...
you need to save these preferences yourself - for example using Label(s) - and make your own script to update saved range
robin
2. Re: (CS3) Is the "rangeName" property of Application.ExcelImportPreference really broken?
Mike.Edel Sep 14, 2009 1:45 AM (in response to AdobeScripts)Hi Robin,
that explains my problems.
I was hoping that InDesign would use Application.ExcelImportPreference.rangeName when updating my placed Excel file.
But since it doesn't store the value its clear why it never did.
Fortunately, Bob Levine pointed me towards a solution: using named ranges in Excel and placing those ranges in InDesign works perfectly.
Mike
3. Re: (CS3) Is the "rangeName" property of Application.ExcelImportPreference really broken?
ldb68 Oct 29, 2009 3:11 AM (in response to Mike.Edel)Hi Mike
"using named ranges in Excel and placing those ranges in InDesign works perfectly"Can you share a sample?
I Use myTextFrame.Place(myExcelFile) with preset and "rangeName" dosen't work
Rem Sets the Excel import filter preferences.
With myInDesign.ExcelImportPreferences
Rem alignmentStyle property can be:
idSpreadsheet = &H73707273
idLeftAlign = &H6C656674
idRightAlign = &H72676874
idCenterAlign= &H63656E74
myInDesign.ExcelImportPreferences.AlignmentStyle = idSpreadsheet
myInDesign.ExcelImportPreferences.DecimalPlaces = 2
myInDesign.ExcelImportPreferences.PreserveGraphics = False
Rem Enter the range you want to import as "start cell:end cell".
myInDesign.ExcelImportPreferences.rangeName = "A1:B3"
REM myInDesign.ExcelImportPreferences.SheetIndex = 1
REM myInDesign.ExcelImportPreferences.SheetName = "Foglio1"
myInDesign.ExcelImportPreferences.ShowHiddenCells = False
Rem tableFormatting property can be:
idExcelFormattedTable = &H786C4654
idExcelUnformattedTable = &H786C5554
idExcelUnformattedTabbedText = &H78555454
myInDesign.ExcelImportPreferences.TableFormatting = idExcelFormattedTable
myInDesign.ExcelImportPreferences.UseTypographersQuotes = True
myInDesign.ExcelImportPreferences.ViewName = ""
End Withthanks
4. Re: (CS3) Is the "rangeName" property of Application.ExcelImportPreference really broken?
AdobeScripts Oct 29, 2009 3:19 AM (in response to ldb68)"using named ranges in Excel and placing those ranges in InDesign works perfectly"
in Excel you can select range of cells and set name:
http://www.contextures.com/xlNames01.html
robin
www.adobescripts.co.uk
5. Re: (CS3) Is the "rangeName" property of Application.ExcelImportPreference really broken?
ldb68 Oct 29, 2009 4:50 AM (in response to AdobeScripts)Tanks Robert
I have seen how create named ranges. I have create a "test" named ranges.
I set import preference as rangeName = "test"
myInDesign.ExcelImportPreferences.rangeName = "test"
End With
Placing the Excel file inside a frame but all the table and not the
During the process I place various files (see script if you as time).
May be these interfer with placing excel file?
I'm using Indesing CS3 5.0 on Windows Vista. I want try Indesing CS3
6.0 to see if is equal.
robin
