I just installed RoboHelp HTML 8.0.0.203 trial on Windows XP (SP3). It's the first RoboHelp
version I've installed on this computer.
No error occured during installation the program starts normally.
1. When I try to create a new empty project the program only creates the folder with
following files and folders:
!SkinSubFolder!
Adobe AIR.ssl
default.css
FlashHelp Pro.ssl
FlashHelp.ssl
Microsoft HTML Help.ssl
testproject.cpd
testproject.glo
testproject.hpr
testproject.ppf
testproject.syn
WebHelp Pro.ssl
WebHelp.ssl
At the moment when the new project file should open nothing happens not even an error
message.
2. When I try to open the sample project file CCC.xpj an error prompt tells me that the
opening of the project was aborted or CCC.cpd couldn't be loaded.
3. When I try to import a PDF (File>New>Project>Import>PDF) an "unexpected error" occures
during conversion.
I already reinstalled RoboHelp and I have administrator rights, but still the same problem.
P.S. I had the same problem on another system with the Robohelp 7 trial some months ago.
But RoboHelp X5 works fine on a third system, I consider an upgrade if the problem can be solved.
I seem to recall from some tests I did once that those are classic signs of not having admin rights.
Is this a standalone PC at home or an office machine on a network? If the latter the first thing is to get IT to check you admin settings.
thanks for the response. The computer with Robohelp 7 was my standalone home PC and the computer where I tried Robohelp 8 today is an office machine on a network. I am sure that I have admin right at home and it is exactly the same issue. But I will check that out again on Monday. My guess is a conflict with another software because in both cases the windows installation is quite old and there are many programs installed. But I have no idea what I have to look for.
I wonder if a firewall could be messing up the install. It doesn't usually happen and it is just a guess. Anyone else got any ideas here?
Well I tested to install RoboHelp 8 on my machine at home where the RoboHelp 7 trial didn’t work. At first with Comodo Firewall Pro enabled and it blocked the two attempts of Windows Installer to access the internet. ->Creating a project still doesn’t work.
Then I uninstalled Robohelp 8 and disabled the firewall. Installed Robohelp 8 again and tried to create a project but it still doesn’t work.
Also I installed Robohelp 8 on different machines at home (XP, Vista Business, 7 Professional) all running with Zonalarm Firewall and it worked.
But installing a new OS is no option for the company especially when everything else works fine.
Before I opened this thread I googled some time for this problem but couldn’t find anything. This is weird because I’ve installed it on two systems which have noting in common besides both run XP.
So it will install on any machine with Zone Alarm but not any machine with Comodo, regardless of operating system, regardless of whether Comodo is active or not.
To me that says Comodo is still controlling something. If not, I would ignore the OS and focus on the fact that something else is likely to be common to the Comodo machines. Maybe those machines also have a different virus checker that is interfering, something like that.
My user account definitely has admin rights.
Comodo is not installed in the company. There is another virus checker/firewall which I disabled for reinstallation of RoboHelp. Before I reinstalled it I cleared the registry from all rests.
But RoboHelp is still not working.
Is there a log file or report file where I could find more information about what RoboHelp is doing during my attempt to create a project? (I already searched but haven’t found one.)
Btw I always install on drive D:\ and not on C:\ but this shouldn’t be the problem I think.
Installing the program to your D Drive could well be the problem, and I am assuming that is a partition on your hard disk rather than a network drive. You will need to check with Technical Support on that.
Yes D:\ is a partition on my hard disk and installing it on C:\ didn't solve the problem.
Sorry but beyond the ideas I have already put forward, I don't know why you are having this problem.
You might want to try http://www.revouninstaller.com to ensure previous attempts are being uninstalled completely but do read the instructions.
