I just reinstalled the cfc generator and can generate the orm cfc's without problems but get nothing if I select 'create CFC' instead of 'create ORM CFC' - I need a non-orm solution for a curren project - is anyone else having this problem?
Susan
Hi Susan,
What is the error you are getting on Clicking option Create CFC?
Evelin
It doesn't give any error message. It does present a dialogue box & after having me fill out the dialogue box, it just goes away and nothing is generated.
Susan
Do refresh the folder selected to generate files and see if files are generated there.
Also there is file bolt.log in server log directory.Can you try to look in to this file and see if it has any errors.
-Evelin
Thanks so much!
Reading the bolt.log did the trick - I had used an Access database instead of MySQL and the error reads that the option doesn't work for Access. There is no problem with MySQL. Is there any documentation for CFBuilder beyond the help file?
Susan
"Error","web-49","09/16/09","12:06:54","SAMPLE CFC GENERATOR","Error Executing Database Query."
"Error","web-49","09/16/09","12:06:54","SAMPLE CFC GENERATOR","[Macromedia][SequeLink JDBC Driver][ODBC Socket][Microsoft][ODBC Microsoft Access Driver]Optional feature not implemented "
