Good call Leo!
This is a well known artifact of dropping swfs into the
Presenter
environment...and for what it's worth, there's another work
around to that "bug" in the following way:
Rather than having all of your animations occuring on the
main timeline in Flash, what you might want to explore is
converting *everything* into movie clips; this way, you can totally
control what happens (and when) based on user interaction.
As an example, I have a sample demo you can view on my site
here:
http://robrode.com/Breeze_demos/myIdentity/index.htm
If you advance to slide 17 of that presentation, what you'll
see is the slide set up and the flash anim located on the lower
section of the slide will just park on frame one. It's only when
you click the thumbnails that the additional animated objects
become visible.
The point in all of this is that more you keep things OFF the
main timeline, the better. Granted, this example is set up such
that we're asking the learner to explore stuff, but with nested
movie clips in Flash, so long as you know how to "call" the movie
clips, you can totally control the playback of your flash content.
Hope that helps!
Rob
Visit my Breeze/Presenter forums!
http://www.robrode.com/yabb/
http://robrode.blogspot.com/
