I'm trying to define he event data using something such as the following:
<?xml version="1.0" encoding="UTF-8"?>
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
elementFormDefault="unqualified" attributeFormDefault="unqualified">
<xs:import schemaLocation="http://myserver:8080/repository/Schema/formabc.xsd" namespace="pi"/>
<xs:element name="Transportation-Notice">
<xs:complexType>
<xs:sequence>
<xs:element ref="pi:formabc"/>
</xs:sequence>
</xs:complexType>
</xs:element>
</xs:schema>
I'm getting a failed to load data event when trying to use the event. Can anyone provide a suggestion?
Total Likes
I do not believe it is possible to use a process variable of type 'xml' in event processing. I would suggest serializing the XML to a string, passing the string to the event handler, and deserializing the XML.
Steve
Total Likes
Can I use a process activity to do that or do I need to write code?
Total Likes
Yes, it can be done in a Set Value operation using functions.
to string - for the expression use the String function string(object?) where object? is the process variable of type 'xml'
to XML - for the expression use the Miscellaneous function deserialize(string)
Steve
Total Likes
Thanks, but it looks like I'm limited to a 4000 character length string for the serialized document due to a database data type constraint. I hope it's enough.
Total Likes
You should be able to pass your xml as part of the Event Message Template portion of the event.
Jasmin
Total Likes
Thank you both. I was able to pass the entire document as xs:xml.
The problem with the string length limit was odd. It appeared that although I changed the lenght limit to unlimited, oracle did not change the data type of the variable.
I kept getting a ORA-01460. So I eventually create a new variable with an unlimited length to attempt to serialize the document. I didn't end up using the string variable, but I did learn a little lesson about how livecycle process variables are persisted.
Total Likes
Likes
Likes
