I can see from the dates on these posts that I'm once again a year behind everyone else - maybe that's a good thing. Could you explain the comment "I wouldn't consider using the inbuilt tool. It only searches on a single line and can miss stuff as a result." I believe I am having this problem. I'm trying to Search / Replace a large project using the RoboHelp Multi-File Find and Replace tool and have discovered it missed about 10% of the hundreds of occurrences. I'm trying to figure out if there's anything I can do differently to avoid this problem. I will look into "variables", but right now I just need to get this project completed for a release. Thanks for any additional info or work-arounds.
I have the same problem - only I'd say it misses more like 30 percent.
Helen Schmidling
Text wrapping means that part of what you are searching for is on one line and part is on another. Many text editor search tools only search on one line. Thus if you are looking for "this string of text" the search will not find it if it is in the code as
this
string of text
because that is on two lines.
You need to use a search tool that does scan two lines such as those recommended.
FAR is also capable of "Start with/Include/Not include/End with" searches, batch runs, and much more.
Good luck,
Leon
Thanks for the observation, the explanation of the mutli-line issue and the recommendation. This would seem to fit what I'm finding. Searching for a single word instead of a string provided considerably better results. I was able to locate the rest of what I wanted to replace by compiling the help and then using the search feature within that. That was enough to get the job done. I'm trying to not install any more applications on my computer but eventually I'll cave in and get a better search tool. Again, thanks.
