Combining several RoboHelp projects into one project.
Sep 16, 2009 Sep 16, 2009
Hello everyone,
I have the following situation:
I have several RoboHelp 7 project files.  Each project is compiled in Flash.  My requirement is that I create one flash file for all of the project files.
To better illustrate, I have the following project (folders) Test1, Test2, Test3 which have the following directory structures.
Test1
     BOOK
          PAGE1
     BOOK
          PAGE1
          PAGE2
     BOOK
          PAGE1
Test2
     BOOK
          PAGE1
Test3
     BOOK
          PAGE1
          PAGE2
The flash file for each will be the same as above.
What I need is a single flash file call NEW TEST which would display the information for all three project files in the following manner:
NEW TEST
     Test1
          BOOK
               PAGE1
          BOOK
               PAGE1
               PAGE2
          BOOK
               PAGE1
     Test2
          BOOK
               PAGE1
     Test3
          BOOK
               PAGE1
               PAGE2
Any way of doing this?  Thanks again!
742
Sep 17, 2009 Sep 17, 2009
Have you thought of mergeing the projects into another "master" project? If you create another blank flash project, and merge the three existing projects into its TOC you will end up with the desired result. I don't use RH7 so can't remember where the merge icon is you use but if you look at the toolbar above your TOC you should see an icon that displays a dialog that allows you to select a project XPJ file. This is used to point to each of the three test projects.
Read the RoboColum(n).
Hi there
In addtion to Colum's fine advice, I will also ask you to clarify exactly what is meant by "compiling to Flash". Do you mean you are creating FlashHelp output from RoboHelp? Or are you using a different tool to gather that content and create a singular Flash file you are distributing?
Cheers... Rick
Helpful and Handy Links
RoboHelp Wish Form/Bug Reporting Form
Begin learning RoboHelp HTML 7 or 8 within the day - $24.95!
Adobe Certified RoboHelp HTML Training
SorcerStone Blog
RoboHelp eBooks
Oct 07, 2009 Oct 07, 2009
Thanks Colum.
Hi Rick,
I have several separate RoboHelp project files that I generate into a flash format and distribute separately.  So my goal now is to create one flash file that combines all of the RoboHelp project files into one "master" help-file.  So yes, I am using RoboHelp to generate my project files into a flash-based layout.
But now I have run into the following issue:
Using Colum's advice, I created a new RoboHelp project and merged each RoboHelp-generated flash helpfile into the new RoboHelp project.
However, when I generate a new layout based on a flash format, the table of contents does not show up.
When I generate a new layout based on a Microsoft HTML format, I can see the table of contents.
What could be causing this problem?
Thanks again.
Oct 08, 2009 Oct 08, 2009
Hi mslwen.
I should state that I am not a FlashHelp user but could your problem be that you are not calling the correct file? The file you need to open must be the one specified in the "Output Folder and Start Page" option of your FlashHelp SSL.
Read the RoboColum(n) for a tips and tricks on Technical Communication Suite products.
RoboHelp Documentation
Download Adobe RoboHelp
