1 Reply Latest reply: Sep 22, 2009 5:04 AM by Tols (UK) RSS
    How to put stage at 0 horz, 0 vert.
    onefiftymph Community Member
      Dir. 11 / MacPro / os10.5.4 / 30" cinema display. I'm upgrading old Dir6.5 movies to new monitor size using my outdated/limited Director skills...
      In authoring and playing full screen (2560x1650pixels) Director shifts the stage down an inch from the top of my monitor.
      Bizarrely, published projector shifts the stage up 1 inch, so either way, the entire 2560x1650 area of my monitor is not being used...
      In Property Inspector/Display Template, there are location fields, but zeroing them do nothing. (What are they for?)
      If there are location input fields to put the stage where I want, I can't find them.
      What gives?
        • 1. Re: How to put stage at 0 horz, 0 vert.
          Tols (UK) Community Member
          in a preparemovie script you could try
          set the rect of the stage to rect(0,0,w,h)
          updatestage
          where w and h are whatever your width and height
          might be overkill (and the second line may do nothing in that handler) but works for me anyway. In authoring I also run a handler which runs the same 'set the rect...' script prior to publishing - who knows, maybe that is the real solution.
