I don't know if you're still looking for an answer to this question, but in Visual Studio's Team Explorer, you can force a project to make all check outs exclusive. The default setting for files under TF version control is that, in general, binary files (images, etc.) are checked out exclusively and text-based files (html, xml, javascript, etc.) are checked out non-exclusively. This can be a problem when multiple RoboHelp authors are working on the same RoboHelp project. Here's how you change your TF project's check-out settings (I believe you need to be a project administrator):
1. In Visual Studio 2008, open the Team Explorer
2. Right-click the TF project where your RoboHelp project(s) reside
3. Select Team Project Settings > Source Control
4. In the Source Control Settings window, select the Check-out Settings tab
5. Uncheck the Enable multiple check-out checkbox
6. While you're here, you can check the Enable get latest on check-out checkbox, if that is your preference.
Good Luck!
Greg
