In RH 8 when I use a DHTML Expanding hotspot, the selected font that I use to put text into the box is not the text that displays when I generate output.
I'm using plain Verdana 12pt, and this is what I see in the output.
until the document owner submits it for review
It doesn't matter what I do to change the font - type, size or any other attribute. When I save the project and regenerate, it looks the same. Is there someting that'
I'm not understanding? I would see correct output in RH HTML 7. Thanks in advance.
Vic
Hi there
Likely you need to edit your style sheet. Open the Styles editor and look for Drop Down Text. When I looked at mine, I saw Expanding Text and it was formatted as you listed above.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 within the day - $24.95! |
Hi there
Cheers... Rick
