Is anyone knows where to find an example for creating the menu and sub-menus in coldusion?
thanks
kt
Well here is one I currently use in one site.
<ul id="menu">
<li>Item 1</li>
<li>Item 2</li>
<li>Item 3</li>
</ul>
<ul>id="subMenu">
<li>subItem 1</li>
<li>subItem 2</li>
<li>subItem 3</li>
</ul>
But then I wouldn't know why you would bother with ColdFusion for this. But then I am guessing that you want something different, but your post gives absolutely no clue on what that something might be.
Some really obvious suggestions are:
* Google "coldfusion menu". There are quite a number of matches.
* I imagine you could even search these forums or just read the recent posts. I've been discussing this with another posted within the last week.
* Do a bit of RTFM. I suggest starting here, with the aptly named <cfmenu>: http://livedocs.adobe.com/coldfusion/8/htmldocs/Tags_m-o_04.html#2929198
Adam
here is a simple example using cfmenu:
<cfmenu name="menu" type="horizontal"
fontsize="14" font="Verdana, Arial, Helvetica, sans-serif" bgcolor="##ff9f40;"
selecteditemcolor="##dd6b04" selectedfontcolor="##FFFFFF" menustyle="border: 1;">
<cfmenuitem name="cfdiv" href="test1.cfm" display="Test1" />
<cfmenuitem name="cfdiv2" href="test2.cfm" display="Test2"/>
<cfmenuitem name="JavaScripts" display="JavaScripts">
<cfmenuitem name="test3" href="test3.cfm" display="test3"/>
<cfmenuitem name="test3a" href="test3a.html" display="test3a"/>
</cfmenuitem>
<cfmenuitem name="Examples" display="Examples" >
<cfmenuitem name="cfgrid" href="cfgrid.cfm" display="CFGrid"/>
<cfmenuitem name="cfgridwin" href="cfgridwindow.cfm" display="CFgrid in Popup Window"/>
<cfmenuitem name="monthDay" href="ymd.cfm" display="day base on month selected"/>
</cfmenuitem>
<cfmenuitem name="cfmenu" href="http://tutorial16.learncf.com/demo/16" display="cfmenu on the fly"/>
</cfmenu>
hope it helps.
