Help ! I can't find the "field" tab for an object in the library
Avatar
Level 1
Just starting out with the software. I want to place a text box that spans several lines and "allow multiple lines" in a form I am building. The only problem is I can't find the field tab for the text box object. The only two tabs I have at the top of the object library is "Object Library" and "Fragment Library"
What am I missing?
Avatar
Former Community Member
Click on the Object Library. Below that there shoudl be three libraries (My Favorites, Standard and Custom). The Textfield is in the Standard library. If all else false you can use the Insert Menu and then choose standard from there.
Paul
Avatar
Level 1
Thanks Paul I have all 3 . As I understand it I should be able to change the properties of the text box object but I can't find the tab or menu to do this
All the help files show the properties for each object available under a field tab that I cannot find.
Dave
Avatar
Under the Window menu choose to activate the Object palette. This palette wil adjust itself to show you properties based on the object selected.
Paul
