OK, in CFChart, I want to have 2 sets of lines, one blue that start at the beginning, and then it turns green and goes to the end. Here's my code:
<cfchart format="flash" chartheight="400" chartwidth="850" showxgridlines="yes" showygridlines="yes">
<cfchartseries type="line" itemcolumn="WeekEnding" valuecolumn="TotalTested" serieslabel="Actual" seriescolor="##0000FF" >
<cfchartdata value="1" item="2009-08-02">
<cfchartdata value="7" item="2009-08-09">
<cfchartdata value="10" item="2009-08-17">
</cfchartseries>
<cfchartseries type="line" itemcolumn="WeekEnding" valuecolumn="TotalTested" serieslabel="Projected" seriescolor="##009900" >
<cfchartdata value="15" item="2009-08-23">
</cfchartseries>
</cfchart>
As you can see, I am trying to get one nice line that switches colors on August 17th. Unfortunately, for the blue line (Actual), it draws a straight line at level 10 to the 23rd. It also draws a green line from the 2nd to 17th at 10. And it sucks!
I tried combining them like this:
<cfchartseries type="line" itemcolumn="WeekEnding" valuecolumn="TotalTested" serieslabel="Actual" colorlist="##0000FF,##0000FF,##0000FF,##009900" >
</cfchartseries>
</cfchart>
But that draws the whole thing green. If anybody has a solution, help would be appreciated. Thanks!
(Repost for the archives) Try modifying the isInterpolated setting in the XML style as mentioned here:
http://www.cftips.net/post.cfm/turning-off-interpolated-data-for-cfcharts
http://www.coldfusionjedi.com/index.cfm/2008/9/17/Ask-a-Jedi-Handling-nulls-in-a-chart
<frameChart autoAdjust="false" is3D="false" isInterpolated="false">
I found the answer on my own (but I hope it helps somebody else out)...
Just add this to your cfchart tag:
style="<frameChart></frameChart>"
I don't quite get it, but it works!
It is due to the default xml settings for cfchart. Look at the link above (one by Raymond Camden). It explains why your change works, and the correct way to control the chart behavior.
Thank you so much for your answer. I have read alot of Raymond Camden's stuff, but I am stuck on something:
IsInterpolated="false" stops drawing lines to the end (good)
it also will not show points if they don't have at least 2 sequential points on the x-axis (bad!)
i.e. my x-axis is every Sunday for about 2 years.
If my datapoints are:
TheDate TheNum
2009-09-20 00:00:00.000 400
2009-09-27 00:00:00.000 450
2009-10-11 00:00:00.000 600
2009-10-18 00:00:00.000 650
2009-11-01 00:00:00.000 750
It will draw the line from Sept 20-27th & from Oct 11th-18th.
It will NOT connect 9/27 and 10/11 and will NOT even show November 1st (unfortunately)
Is there a happy medium here? I want to see all of my data (and it would be nice to see lines) and don't want it to draw to the ends.
