8 Replies Latest reply on Mar 24, 2011 4:44 AM by BorekB
    Is there a way to suppress warnings in FlexPMD?
    jacornwell
      In PMD there is the @SuppressWarnings java annotation that can be used to suppress all or individual warnings in a class. Is there anything similar that can be added in an AS or MXML file with FlexPMD?
        • 1. Re: Is there a way to suppress warnings in FlexPMD?
          Xavier Agnetti Pioneer
          So there is a way to suppress one or all violations in a given line by appending // NO PMD or // NO PMD ruleName
          There is no way at the moment to ignore every violation at a class level, or function level using metadata.
          Feel free to add a feature request if you think it is needed.
          Xavier
          • 2. Re: Is there a way to suppress warnings in FlexPMD?
            jacornwell Newcomer
            Thanks Xavier. That worked well.
            • 3. Re: Is there a way to suppress warnings in FlexPMD?
              Glad to hear that.
              To be more accurate, // NO PMD ruleName has been added in Rc4, that has been released today
              Cheers,
              Xavier
              • 4. Re: Is there a way to suppress warnings in FlexPMD?
                Marc Kubischta
                FlexPMD is giving me a warning "adobe.ac.pmd.rules.performance.CreationPolicySetToAll" in an <mxml:Application> declaration. Is there a way to suppress this warning, or am I out of luck?
                Thanks -
                Marc
                • 5. Re: Is there a way to suppress warnings in FlexPMD?
                  Can you attach an example?
                  Xavier
                  • 6. Re: Is there a way to suppress warnings in FlexPMD?
                    MSheth
                    Xavier,
                    I am seeing tons of warning messages as under. I am using ANT target to invoke FlexPMD. Can you suggest a way I can hide these messages ? I did //NO PMD for all our rules ...
                    [flexPmd] WARNING: Open quote is expected for attribute "type" associated with an  element type  "node". at org.apache.xerces.util.ErrorHandlerWrapper.createSAXParseException(Unknown Source)
                      [flexPmd] org.apache.xerces.util.ErrorHandlerWrapper.fatalError(Unknown Source)
                      [flexPmd] org.apache.xerces.impl.XMLErrorReporter.reportError(Unknown Source)
                      [flexPmd] May 6, 2010 10:49:44 AM de.bokelberg.flex.parser.AS3Scanner$XMLVerifier verify
                      [flexPmd] WARNING: The markup in the document preceding the root element must be well-formed. at org.apache.xerces.util.ErrorHandlerWrapper.createSAXParseException(Unknown Source)
                      [flexPmd] WARNING: Open quote is expected for attribute "label" associated with an  element type  "workItems". at org.apache.xerces.util.ErrorHandlerWrapper.createSAXParseException(Unknown Source)
                      [flexPmd] WARNING: Open quote is expected for attribute "type" associated with an  element type  "nodes". at org.apache.xerces.util.ErrorHandlerWrapper.createSAXParseException(Unknown Source)
                    • 7. Re: Is there a way to suppress warnings in FlexPMD?
                      This warning has been removed.
                      Cheers,
                      Xavier
                      • 8. Re: Is there a way to suppress warnings in FlexPMD?
                        BorekB Newcomer
                        In the current release of FlexPMD is there a way to suppress errors/warnings on the class level yet?
                        Borek
