Anyone? Store Procedures
Participant ,
Sep 24, 2009 Sep 24, 2009
Good afternoon all,
I created a stored procedure in SQL from:
<cfquery name="rsDisposition" datasource="#REQUEST.datasource#">
SELECT tlkp_Defects.Defect_Title,
  SUM(case WHEN tbl_Assembly_Holds.Disposition_ID = 1 then 1 else 0 end) FixedOnLine,
        SUM(case WHEN tbl_Assembly_Holds.Disposition_ID = 2 then 1 else 0 end) Repair,
        SUM(case WHEN tbl_Assembly_Holds.Disposition_ID = 3 then 1 else 0 end) Scrap
FROM
    tbl_Assembly_Holds
    join tlkp_Disposition on tbl_Assembly_Holds.Disposition_ID = tlkp_Disposition.Disposition_ID
    join tbl_Assembly_Hold_Defects on tbl_Assembly_Hold_Defects.TagNumber = tbl_Assembly_Holds.TagNumber
    join tlkp_Defects on tbl_Assembly_Hold_Defects.Defect_ID = tlkp_Defects.Defect_ID
WHERE
  tbl_Assembly_Holds.Record_date Between '#FORM.dateFrom#' And '#FORM.dateTo#'
GROUP BY
</cfquery>
I am trying to call it from CF8 but I am getting errors, here is my code:
<cfstoredproc procedure="defect_yield" datasource="#REQUEST.datasource#">
<cfprocparam type = "IN"
   CFSQLType = CF_SQL_DATE
      value = "#FORM.dateFrom#">
      value = "#FORM.dateTo#">
</cfstoredproc>
Any ideas on how to make this work? I want convert most of queries to Stored Procedures.
Thanks in advance,
DJ Khalif
Advanced techniques
1.0K
Valorous Hero , Sep 24, 2009 Sep 24, 2009
Procedure defect_yield has no parameters and arguments were supplied.
ALTER PROCEDURE .[defect_yield]
(No parameters defined here)
AS
SELECT
As the error message says, you are passing int two arguments (#FORM.dateFrom# and #FORM.dateTo#), but your procedure does not expect any. If you want to pass variable dates into the procedure, you need to add those parameters to your procedure declaration
@DateFrom DATETIME,
@DateTo DATETIME
AS
SELECT
WHERE productDetail
Valorous Hero ,
What do you mean by "created a stored procedure in SQL form"?
If your first <cfquery....> block was supposed to be a stored procedure....
Every time I have ever seen stored procedure SQL code it started of with "CREATE OR REPLACE STORED PROCEDURE"....
But since you gave such a vague description of your problem with no indication what errors you are experiencing or how your code is not working... I am really guessing on what the issue might be.
Valorous Hero ,
But what error are you receiving and what does the actual stored procedure sql look like?
Participant ,
Ian,
I created the SP using the query in within the block. I verified in SQL 2005 by entering actual dates in '#FORM.dateFrom#' and ....
Below is the error:
Error Executing Database Query.
[Macromedia][SQLServer JDBC Driver][SQLServer]Procedure defect_yield has no parameters and arguments were supplied.
The error occurred in C:\inetpub\wwwroot\AtticaProducts\excelPages\dispositioncount.cfm: line 7
5 :       <cfprocparam type = "IN"
6 :    CFSQLType = CF_SQL_DATE
7 :       value = "#FORM.dateTo#" dbVarName = @param2>
8 :
9 : </cfstoredproc>
SQLSTATE  HY000
SQL  {call defect_yield( (param 1) , (param 2) )}
VENDORERRORCODE  8146
DATASOURCE  atDat
SP:
USE
[productDetails]
GO
/****** Object: StoredProcedure [dbo].[defect_yield] Script Date: 09/24/2009 14:49:40 ******/
SET
ANSI_NULLS
ON
GO
SET
QUOTED_IDENTIFIER
ON
GO
ALTER
PROCEDURE [dbo].
[defect_yield]
AS
SELECT
productDetails.dbo.tlkp_Defects.Defect_Title,
SUM(case WHEN productDetails.dbo.tbl_Assembly_Holds.Disposition_ID = 1 then 1 else 0 end) FixedOnLine
SUM(case WHEN productDetails.dbo.tbl_Assembly_Holds.Disposition_ID = 2 then 1 else 0 end) Repair
SUM(case WHEN productDetails.dbo.tbl_Assembly_Holds.Disposition_ID = 3 then 1 else 0 end)
Scrap
FROM
productDetails
.dbo.
tbl_Assembly_Holds
join productDetails.dbo.tlkp_Disposition on productDetails.dbo.tbl_Assembly_Holds.Disposition_ID = productDetails.dbo.tlkp_Disposition.
Disposition_ID
join productDetails.dbo.tbl_Assembly_Hold_Defects on productDetails.dbo.tbl_Assembly_Hold_Defects.TagNumber = productDetails.dbo.tbl_Assembly_Holds.
TagNumber
join productDetails.dbo.tlkp_Defects on productDetails.dbo.tbl_Assembly_Hold_Defects.Defect_ID = productDetails.dbo.tlkp_Defects.
Defect_ID
WHERE
productDetails
.dbo.tbl_Assembly_Holds.Record_date Between 'productDetails.dbo.tbl_Assembly_Holds.Record_date' And
GROUP
BY
productDetails
.dbo.tlkp_Defects.
Defect_Title
Valorous Hero ,
AS
SELECT
@DateFrom DATETIME,
@DateTo DATETIME
AS
SELECT
WHERE productDetails
GROUP BY .....
Once you add the parameters, you can use those SQL variables within the procedure's query, just like in your original cfquery. More or less.
WHERE tbl_Assembly_Holds.Record_date Between @DateFrom AND @DateTo .....
Participant ,
Sep 25, 2009 Sep 25, 2009
cfsearching,
That did it. I added the following:
      value = "#FORM.dateFrom#" dbVarName = @DateFrom>
      value = "#FORM.dateTo#" dbVarName = @DateTo>
<cfprocresult name = Defect>
</cfstoredproc>
...and it worked. I want to speed up my process time and portability of my application.
Thanks.
DJ Khalif
Valorous Hero ,
Do not use dbVarName, it is deprecated.  You must use positional notation.  ie The order of your cfprocparam statements must match the declaration of the variables in your stored procedure SQL or an error may occur.
Assuming the forum did not mangle your code, you may want to add some quotes there. Just to keep the code clean.
Engaged ,
Here's a tip...
Always test your stored procedure by trying to call it within the SQL development-environment, exactly as you intend for ColdFusion to call it.  Make sure that it works as you intended, then address the now-separate issue of getting the ColdFusion call to work.
Valorous Hero ,
Sound advice.  There is no point adding CF to the mix if you are not even certain the procedure works as expected ... or at all.
Participant ,
Sep 27, 2009 Sep 27, 2009
cfsearching,
Before I attempted this is CF, I ran in SSMS but I had static dates. It worked.
DJ Khalif
Documentation
