Show 4 replies
1. Re: spot colors
[scott] Sep 25, 2009 1:31 AM (in response to Ief_DR)What settings (Job Options) are you using when saving to PDF?
2. Re: spot colors
Ief_DR Sep 25, 2009 1:40 AM (in response to [scott])I've tried illustrator default, press quality and PDF/X-1a:2001
4. Re: spot colors
Ief_DR Sep 25, 2009 11:55 AM (in response to PrepressPro1)I use two spot colors: pantone 293c and pantone 354c. They are all set to Book Color.
In Illustrator CS4 and Indesign CS4 everything looks fine (overprint preview checked). In Acrobat CS4 everything looks dull. It's better when I use the PDF-profile: ScreenPrintSpot_1v4_IND4.joboptions in Indesign (http://www.gwg.org/index.php?search=&vendor=all&version=all&app=indesign+cs2-cs4®ion=al l&segment=all&color=all&precre=all&res=all&id=9%2C191%2C0%2C0%2C1%2C0).
Is it normal the spot colors look dull in Acrobat. Am I doing something wrong?
Ief
